Changing front brakes, 95 Mustang, problem!
Old February 6th, 2007, 03:47 PM   #1
cgyarring is on a distinguished road
Changed out the rear brakes and calipers, and the front left one, but upon popping off the front right tire I found that the 2 bolts which mount the caliper are stripped. 1 needed a hex screw which is pretty much rounded out and the other is an odd bolt, which seems to have notches in it. If I could figure out what tool would be used for this I would be able to take it off, but I'm clueless as to what it would be.
It's similar to a hex bolt, except each side has a notch in it. If anyone knows what tool to use, please let me know, other wise, I'm semi fucked as my pads are in dire need of a change!
Oh, 95 Mustang, V6, all stock brakes if that makes a difference.
Old February 21st, 2007, 09:10 PM   #2
jagstang96's Avatar
jagstang96 is on a distinguished road
well its not a hex do not use a hex or u will damage the bolt more. what u need is called a torx bit , it is star shaped i think u need a t45 or t50 size available anywhere , just go to autozone they have them they are like 10 dollars or less>>>
Threads Similar to: Changing front brakes, 95 Mustang, problem!
Changing the front corner lights......Question? Bossman 2005 - 2010 44 September 22nd, 2007 07:29 PM
Front Brakes HELP! bbrewer03 96-98 4 May 31st, 2007 11:01 PM
Front brake problem 99 mustang Justin07 V6 Mustangs 10 November 22nd, 2006 08:08 PM
Changing front clip 90Stang 5.0 Mustangs 0 November 21st, 2006 06:03 PM
2002-front disc brakes-standard 6 cyl mustang Skee General Tech 0 October 21st, 2006 11:28 PM
