camber caster plates
I installed camber caster plates this weekened and I set my caster at 3 degrees which is as far back as it will go towards the fire wall. I noticed that the shock itself is now underneath the original big hole that it came up thru to tighten the top nut on it. With the caster set way back the top of the shock the rubber piece which I guess is the bump stop is half under the shock tower and half under the plate and the original factory hole. Is this alright like this. I followed the instructions just as it said
Resident Bubblehead
i haven't installed cc plates myself. i would probably take it to a goo alignment shop and have them set it up for you.
what kit did you use?
**stroke'n** |
Threads Similar to: camber caster plates
| caster/camber plates | ricks01 | General Tech | 12 | July 18th, 2007 04:26 PM |
| Camber Caster Plates | MustangMatt96GT | 96-98 | 6 | February 18th, 2007 09:04 AM |
| CASTER/CAMBER PLATES? | PONYBOY14 | General Tech | 2 | February 4th, 2007 04:24 AM |
