Discussing Studs or Bolts? in the General Tech Forum. which is better? head studs or head bolts?...
Old February 23rd, 2007, 06:42 PM   #1
Fastpitchdad's Avatar
Studs or Bolts?
Old March 1st, 2007, 12:01 PM   #2
WAR-PARTY's Avatar
2001 YUGO GT
Spend the money and get ARP head studs, there are many reasons. best of all you can re-use them if you have to change head gaskets.....
Old March 1st, 2007, 12:09 PM   #3
Zippee is my step sister.
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
HEAD STUDS vs. BOLTS...
A TECHNICAL DISCUSSION from ARP
ARP’s factory Tech Representatives are often asked which
is better, cylinder head studs or bolts. The answer, invariably,
depends on the installation. On many street-driven vehicles,
where master cylinders and other items protrude into the engine
compartment, it’s probably necessary to use head bolts so that
the cylinder heads can be removed with the engine in the car.
For most applications, however, studs are recommended.
And for good reason. Using studs will make it much easier to
assemble an engine (especially a racing powerplant which must
be serviced frequently and quickly!) with the cylinder head and
gasket assured of proper alignment.
Studs also provide more accurate and consistent torque
loading. Here’s why. When you use bolts to secure the head,
the fastener is actually being “twisted” while it’s being torqued
to the proper reading. Accordingly, the bolt is reacting to two
different forces simultaneously. A stud should be installed in
a “relaxed” mode – never crank it in tightly using a jammed
nut.
If everything is right, the stud should be installed finger
tight. Then, when applying torque to the nut, the stud will
stretch only on the vertical axis. Remember, an undercut
shorter stud will have a rate similar to a longer, standard shank
stud. This provides a more even clamping force on the head.
Because the head gasket will compress upon initial torquing,
make sure studs and bolts are re-torqued after the engine has
been run.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft
Old March 1st, 2007, 08:07 PM   #4
Thanks darrell and war party..
studs it is
Threads Similar to: Studs or Bolts?
Wheel Studs! MustangMatt96GT 96-98 0 September 12th, 2007 07:49 PM
studs or bolts mustangman36578 96-98 1 March 29th, 2007 12:25 AM
Does a 94 gt have studs in the fender emblem? Snake studs:-( 1911A1 5.0 Mustangs 1 February 24th, 2007 04:00 PM
arp studs skipb88 V6 Mustangs 0 January 7th, 2007 03:20 PM
Head studs Vs Head bolts turbong 5.0 Mustangs 2 November 29th, 2006 05:28 PM
