struts
Old March 24th, 2006, 02:27 PM   #1
zhunter is on a distinguished road
Send a message via MSN to zhunter
struts
the strut on the front driver side is making a squeaking noise whenever i go over a large dip or bump, i figure its time to change out those struts, but i wanted to get a second opinion.
Old March 24th, 2006, 02:41 PM   #2
Bill is on a distinguished road
i would look into your tie rod ends first. i had a 94 and that did that and it was the tie rod end. ford dont use grease fittings and over time it squeaks.
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Old March 24th, 2006, 02:43 PM   #3
how hard is it to change the tie rod ends out? i can get all of them at a discount through work, so if i can do the job myself in like a day, then ill go ahead and do that. the weird thing is, it only squeaks when its really warm outside...
Old March 24th, 2006, 05:40 PM   #4
Roadhawg is on a distinguished road
Takes 30 minutes at most.
You need to jack up the car and support it.
Remove the tire.
Remove cotter pin from the crown nut.
Remove crown nut.
Use a tierod separator AKA (Picklefork) to remove tierod from hub.
Loosen lock nut on the rack-n-pinion side of tierod.
"Important" Count the number of turns required to remove tierod from rack-n-pinion.
Install new tierod by screwing tierod on to rack-n-pinion the same amount of turns it took to remove it.
Tighten lock nut.
Install tierod into hub.
Install crown nut.
Install cotter pin.
Install tire...........................
2003 Mustang Mach1
1995 Thunderbird LX 4.6L;
1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph
Old March 24th, 2006, 05:51 PM   #5
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
while you are under there, check the bushings on the front swaybar too
Threads Similar to: struts
What struts to use? smithbuilt24 99-04 11 November 5th, 2007 04:06 PM
Struts. Hudstang 96-98 5 July 18th, 2007 08:07 PM
struts... Sickstick General Tech 1 May 18th, 2007 09:08 AM
struts patwrecked General Tech 1 April 24th, 2007 11:30 PM
Fun with struts OTreborO General Tech 0 May 5th, 2006 04:20 PM
