Discussing brakes in the General Tech Forum. we just changed the brakes and rotors on my mustang, and the brake cylinders wont ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
brakes
we just changed the brakes and rotors on my mustang, and the brake cylinders wont compress so i can put the new pads back on. Am i missing something huge that is different on mustang's?
Thanks |
Front or rear? The front should compress the same as any other vehicle with disc brakes. I believe the rears require a specialty socket that actually threads the piston back into the caliper.
#3 | |
88 Mustang Coupe 2006 FFW Richmond True Street Runner-Up www.rickscarcare.net http://img146.imageshack.us/img146/2158/ricksadql2.jpg |
#4 | ||
Yeah, I did the same about 4 years ago. Right after that I went out and bought one of the sockets. Its still in my toolbox in the original packaging.
yeah its the rear, what kind of tool is it?
Maintenance Man
11.47@120.58
It's a small cube that you stick on the end of a ratchet. Parts stores sell them for about $12 I think.
Hey Thanks a lot guys
1999 Ford Mustang V6
haha, i use a set of flat tipped pliers
2003 Cobra & 2002 GT
Yea I bought one of the universal sockets from napa that has like 6 sides to it and then ended up having to use pliars cause the bitch was too stubborn to move with the socket lol
Need some decals for that ride?? Http://www.SnowdonDSign.com 4 Generations of Real Estate Experience Working For You Broker/Owner Http://www.SnowdonRealty.com |
I always use pliers u get use to it if not there is a trick to it if they don`t want to go back in use a regular brake cylinder
compressor tool compress at the same time use a large pliers to turned the cylinder just make sure u don`t damage the boot it always work...
http://www.moddedmustangs.com/hosted...rd-mustang.jpg SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$% |
I also recently had all my brake pads replaced with ceramic pads, and had all the rotors turned. After a few weeks, I noticed a low clicking noise from my rear brakes while driving. (It sounds a lot like a pebble stuck in the tire).
When I apply the brakes, the noise stops immediately. There are no other problems with the brakes, and this noise is intermittent. The guys at the garage said that "doing the rear brakes was harder than doing the fronts". I'm slowly catching on, I think. Does the noise mean that my rear brakes need to be adjusted somehow? Is the noise coming from the pads dragging on the rotors? Thanks, Joe
1998 Laser Red V6 manual . . . Kenny Brown suspension, Eibach pro-kit springs, ASP 25% UDP, BBK CAI, JBA shorty headers, Magnaflow duals, Aluminum driveshaft, 3.27 gears |
there's not much to adjust, you could just re-torque the bolts and make sure they are tight, but there is a metal clip that gets re-used on the new pads, maybe this did not get transferred to the new set? it is shown as #5 on the attached diagram, you also might want to check the rotor surface to make sure no debris is stuck in the pad making a groove in your rotor.
I have a 2002 Mustang GT and I am attempting to change the rear disc brakes. I undid the caliper bolt and slid the caliper upright to attempt to change the pads but the piston is still compressed too tight to let me get the pads out. Now I read that there is a tool to reset the piston and I assume that I need to reset the piston before I attempt to remove the old pads. Please correct me if I'm wrong. What I need to know is where do I use this special piston resetting tool is it in front of me or behind the rotor? I am still used to using a clamp so this is different. Also what is the tool called so I know what to ask for?
Threads Similar to: brakes
| Brakes | jim.munoz | V6 Mustangs | 13 | March 25th, 2008 10:53 AM |
| Brakes on AM? | energiesource | 99-04 | 9 | November 9th, 2007 11:33 PM |
| Brakes (Brenspeed) | Bhblondguy | 2005+ | 7 | September 10th, 2007 12:20 PM |
| 88 GT brakes | Blitzkrieg | 5.0 Mustangs | 3 | May 15th, 2007 07:31 AM |
| Brakes | UNFStang | Modular Mustangs | 2 | November 6th, 2006 02:06 AM |
