What all is need after buying a Vortech Tuner Kit?
I am getting a new Vortech V3 SI trim Tuner kit for 2500.
The kit comes with the Head Unit and the following. * Discharge tubing * Compressor bypass valve * Mounting brackets * Supercharger drive pulley * Integrated belt tensioner * Drive belt * Clamps * Mounting hardware For those who have put together their own kit. Im trying to figure out what else Ill need. So far I can think of Fuel Pump Injectors Chip/Tune Am I missing anything?
99 GT MMR600 |
2003 Ford Mustang GT
The intake tubing/piping. An upgraded Mass Airflow Sensor (MAF) - lots of people upgrade to the 90mm Lightning MAF. I would make sure the injectors are 42lbs or more, and the fuel pump most people go with either an SVT Focus fuel pump, a single or dual Cobra pump setup, or a Ford GT pump set up. I believe I listed those in order of price, probably.
Other than those I think you've got everything you need, but i'm sure more experienced people who actually have a Vortech kit will respond as well.I'm looking to do the same thing you are doing, so I have been doing a lot of research as well. I would recommend looking into some form of cooling off the air charge too. Your choices are, as far as I know, Vortech's air-to-water aftercooler, methanol injection - it's cheaper than the intercoolers and provides you with a cooler air charge and can change the octane rating of 93 octane fuel to around 100 so its more like race gas which allows you to run a little more timing to make more power without detonation (which is the whole point of the intercooling idea anyway), or you can go with a front mount intercooler (FMIC) - lots of companies make these, some people have had success with brands like CXRacing and Treadstone, they are relatively cheap when compared to the air-to-water intercoolers and are as cheap in some cases as methanol injection without the hassle of replacing fluids, ie water, ice for the water, or methanol/water mix. ...wow that was a lot of typing for a relatively simple response, sorry about the essay I just wrote, lol.
Threads Similar to: What all is need after buying a Vortech Tuner Kit?
| Buying the Right Tuner | 02GT89 | 99-04 | 28 | February 13th, 2010 01:20 AM |
| buying a used vortech v2 | LythGt420 | 99-04 | 16 | July 20th, 2009 12:44 PM |
| Buying A Vortech | shadow5403 | V6 Mustangs | 12 | December 14th, 2007 01:55 PM |
| buying a vortech | k2boarder3187 | 96-98 | 9 | June 25th, 2007 06:28 PM |
