Rear End Gear Swap Help
I have a 1998 GT with stock 2.73 gears. I am getting ready to install 3.55 gears but would like to do it myself. Can someone put a step by step map for me to follow? Thanks
Rear gears is a very scientific process. I wouldnt recomend trying them on your own for the first time. Just my 2 cents.
1999 Ford Mustang V6
14.79 @ 92.15
You'll not be satisfied w/ 3:55's...
Go 4:10's, hand down for the win... And take it somewhere, 9 times out of 10 somthing will go wrong if you haven't done it before..
...Modded 1996 Ford Mustang GT... SOLD!!
...Modded 2001 Ford Mustang SVT Cobra... SOLD!! Now... ...Modded 2003 Ford Mustang SVT Cobra, Anniversary Edition.. www.cardomain.com/id/po1snd_u |
2001 YUGO GT
Bossman351 has a real good point I been building cars for 30 years and still take my car to a rear end guy, it is well worth the money // usualy 300 to 500 dollars depending on just what you are having done and the amount of parts you supply. We are all good at at least one thing, if age has taught me anything it's know your limits and go with what your good at. W.P.
yep basicly same thing i did, all i did was disassymble the axles from the center and sand blasted the rearend primered it and took it to a rearend shop to get the center rebuilt then after that i painted it before final assymbly of the axles.
Just my opinion go with 3.73 gears cause my boys have gts as well and they have all the same shit exept for gears. I mean same year, engine work. The one with the 3.73 gears puts it on the one with 4.10 gears plus it get lttle better gase milage. also they are both 99 gt's.
!994 mustang with 96 3.8l engine. Ram air intake, Helix tower power throttle body space, dual exaust w/flowmaster's, 98 gt rearend 8.8 w/ 327 gears,SCT Xcalibrator 2 sf, and lots of audio and entertainment
Once I bought my 4:10's and trac-loc rebuild kit, I had a shop install them both for $256....well worth it!
1982 GT (t-top) 351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's Best E.T 12.85@102mph |
well, my 2 cents agrees that you should go with the 4.10's at least, and depending on your mechanical abilities and skill level determine whether you do it or not
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
3.90s
but have a shop do it as they say...ive seen ppl get it in for $200
I am going to echo the thoughts of everyone else and say "SHOP!!!"
But, if you DO want to do it yourself, there is nothign wrong with it. I've done it a couple times myself.. you MUST, repeat MUST understand the procedure before you take things apart... and you will have to be a patient guy because it will take a bit to get it done right the first time. I had an experianced rear end guy with me when I did mine, and I was still able to screw stuff up.. *side note* chris, do you take the middle ground just to argue or be different, LOL some say 3.73, some say 4.10... and you go 3.90 LOL LOL
Threads Similar to: Rear End Gear Swap Help
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 05:33 PM |
| 2006 Mustang GT Rear Gear Swap? | kcwhunter | 2005 - 2010 | 6 | November 14th, 2007 10:49 PM |
| Gear Swap on a 98' | Bpuckhead89 | V6 Mustangs | 1 | July 18th, 2007 04:52 PM |
| 3.73 gear swap | droppedbass87 | 96-98 | 15 | May 19th, 2007 12:08 PM |
| auto rear end gear swap | stepfaster2000 | 99-04 | 5 | March 23rd, 2007 01:12 AM |
