Power windows problem, a temperature thing? - Forums at Modded Mustangs
post #1 of 11 Old March 18th, 2010, 06:56 PM Thread Starter
Send a message via Yahoo to ZsMach1
I have been having this problem on and off since last summer, when it is hot my power windows stop working. During the summer they stop working, fist one then the other. Once winter came they were purfect like nothing was ever wrong. Its starting to get hot again and BAM the driver side has stop working and im sure the passenger side will do the same when it gets hotter. I first thought they were sticking cause of the heat but I jiggle and wiggle them and nothing. Ideas? Motor?
ZsMach1 is offline
post #2 of 11 Old March 18th, 2010, 07:02 PM
vita's Avatar
Send a message via AIM to vita Send a message via Skype™ to vita
power window fluid?
i dunno... i would think the motors would work better under hot, and lock up when its cold.
Originally Posted by mrsinister2424 View Post
... I roll up with my retarded exhaust setting off car alarms and wetting panties for miles.
MM Cobra Club Member #51
vita is offline
post #3 of 11 Old March 18th, 2010, 09:25 PM Thread Starter
I know, its crazy. The whole winter they were working great, not even hesitating or anything. Got a little hot and now they wont go down.
ZsMach1 is offline
post #4 of 11 Old April 14th, 2010, 01:50 PM
Look Ma! My First Post!
I have the same problem with my 2003 mustang. Usually the drivers side, when parked in direct sunlight. the window works fine in the cool morning, but at lunch time, no luck! I can hear a click when I hit the button, but nothing else. the passenger side works fine. If you figure out what's wrong, let me know! I don't want to waste time or money on having a dealer look at it again. The last time they couldn't find anything wrong, probably didn't believe the crazy girl and took it apart in the morning when it was cool!
bamcclain is offline
post #5 of 11 Old June 7th, 2010, 03:20 PM
temperature issue
I have had the exact same issue with my 04 since summer 2005. I usually roll the window up, but not all the way up, perhaps the last 1/8 inch or so. The window is all the way up so rain wont get it, but not all the way up in the track. This is the way I have combatted it, but would rather know to fix it. Well, Saturday, my passenger window started doing it. I have asked mechanincs and dealers alike and they all dont know what causes this. Only when its hot. Doesnt make sense. If anyone could help, please send me a message.
jvalentine1976 is offline
post #6 of 11 Old August 21st, 2010, 07:25 PM
We are having the same problem with our 2000 mustang. The driver side window seems to work only when it's cool outside. The window hasn't worked all summer, however the day I schedule to take it to get looked at, it started working again. So ofcourse they can't do anything unless it doesn't work. This happened last summar as well.
tiger278 is offline
post #7 of 11 Old August 23rd, 2010, 09:38 AM
I have similar problems as you guys but mine happens to be something in the door lock, when its hot and I go to lock the door the horn beeps twice letting you know one of the doors is still open but neither are, and the dome light stays on inside and drains the battery. And on the instrument cluster it doesnt say door ajar either
03sonikblu is offline
post #8 of 11 Old August 23rd, 2010, 09:44 AM
my dome light did that also....then yesterday while i was playing around in my car, the key alarm started going off without the keys in it???? couldnt figure it out, but i opened up both my doors/shut them/cycled the keys off and on a couple of times...nothing!! then when i got fed up with it and was like screw it let the battery go dead and slammed the door and walked away from it....it stopped! i calling Gremlins!
JLT Ram Air Intake/Accufab 70mm Throttle Body & Upper Plenum/SLP Longtube Headers/SLP Catted X-pipe/SLP LM1/4.10 gears
Military Crew - AZ2(AW)
Black Stang Member #6
pyschopath76 is offline
post #9 of 11 Old March 8th, 2013, 10:04 PM
StangGT96's Avatar
Not meaning to bring bad a really old thread but I'm doing research and having issues with my driver side window. Mornings and nights it works but when I leave work and car been in the direct sun all day it doesn't work. Any ideas?
1996 GT- Sold
2001 GT- Sold
2003 Mach 1 AB-Sold
2015 GT
Go Big or Go Home!
StangGT96 is offline
post #10 of 11 Old May 13th, 2013, 04:48 PM
Hey StangGT96, I came across this forum while Googling a similar problem with my 98 Escort (which I believe uses the same chassis as the Mustang, at the time). I came across this link that might help you out. I just tried it without success, but it could be helpful for you or other errant Googlers who might find this.
Also, if you've discovered your own solution to this in the meantime, I'd love to hear it.
Last edited by shrimpy89; May 13th, 2013 at 04:49 PM. Reason: Had to post a message before including helpful link.
shrimpy89 is offline
post #11 of 11 Old May 25th, 2014, 10:50 AM
Sticking power window fix.
Sorry about digging up an old thread, But I found something that seems to work for me.
I had this issue for a while on the driver's side window of my 2003 mustang. As in the webpage linked to in the previous post noted, the grease used in the power windows gets harder when warm. I cleaned off all the old hard white grease off the window regulator and out of the motor assembly, and put on new fresh grease. I had some high temp wheel bearing grease left over and used that. It seems to be working now without any issues.
Mark_S2003 is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/157542-power-windows-problem-temperature-thing.html
2003 mustang powerwindows problems This thread Refback April 23rd, 2013 10:19 PM
2003 Ford Mustang Power Windows - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback April 15th, 2010 06:47 PM
You may not post new threads
You may not post replies
