Using Nitrous
Old March 30th, 2006, 10:11 PM   #1
streetstang06 is on a distinguished road
Using Nitrous
I'm looking to get a nitrous system for my car however i want to know how it is supposed to be used first. How long are you supposed to use it at once? Or can you just continue to hold the button as long as you need too? I'm new to this so any information will help. Thanks
Old March 30th, 2006, 11:02 PM   #2
Drgnracin72's Avatar
they mae a wot switch that will activate the n2o for the full time while the throttle is full pressed. it will pray the entire track. what exactly are you running this on?
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old March 31st, 2006, 06:52 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You can run it until the bottle is empty. A wide open throttle switch is better to use than a push button. You should only spray nitrous at wide open throttle. With a wide open throttle switch you will only be able to spray it at wide open throttle. Do not spray under 3000 rpm. Pull 2 degrees of timing out per 50 horsepower of nitrous and read the instructions and set the fuel pressure accordingly.
Old March 31st, 2006, 08:17 AM   #4
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
you can also setup a dual stage configuration and where it sprays based on your set window pills.
Old March 31st, 2006, 07:54 PM   #5
hitman38mod is on a distinguished road
You need a wot and arming and fire switch posted pics.
Old July 2nd, 2006, 11:20 PM   #6
89Domindart's Avatar
89mustanglx5.0
89Domindart is on a distinguished road
Send a message via AIM to 89Domindart
this is good info..! :award
I used to run my nitrous for many seconds while racing.. i tried not to be TOO hard on my engine.. but it still runs strong today..
the switch for it at WOT is at ur throttle body butterfly.. when it opens all the way it clicks the button there..
why cant u spray under 3000?
looking for a mustang again.!
Old July 3rd, 2006, 11:39 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
There are a few reasons. Ignition timing is usually all in by 3000 rpm, above 3000 rpm the engine is less likely to bog or hesitate, etc. A hesitation when spraying is disasterous. I've sprayed under 3000 rpm already with no problems on my old daily driver but it isn't recommended.
Old July 6th, 2006, 01:21 PM   #8
NXbottleboy is on a distinguished road
go with the full throttle switch
Threads Similar to: Using Nitrous
Nitrous Goblin General Tech 0 November 12th, 2007 03:42 PM
nitrous mustangboy8909 5.0 Mustangs 6 July 29th, 2007 09:33 PM
what do you think of nitrous Badasstang281 99-04 51 January 7th, 2007 06:07 AM
Nitrous ?'s bwb3 5.0 Mustangs 5 November 27th, 2006 04:31 PM
