LinkBack (1) | Thread Tools |
#1
1986 Mustang GT
Mustang Won't Start Please Help
Alright, i have an 86' GT with the 5.0 (manual) in it, i am having a problem with it starting. It is an all original car with about 210k miles on it, the only thing it has done to it is a k&n air filter and a sound system that is hard wired into the factory stereo wiring harness. Now i was driving to work a few days ago and i make it to the road that my job is on and all of the sudden i have no throttle response, the radio was still playing and the lights never dimmed so i assumed i had just stalled the car so i pushed in the clutch and tried starting it while i was still driving but it didn't start so i just coasted into the parking lot. I turned off the radio and tried again to start it, no luck. So i went to work and when i got off my uncle came to help me trouble shoot, we pulled the spark plugs and did a spark test and it was strong (the spark plugs are old but they were not oil covered and it isn't running rich or lean) so we checked to see if the fuel pump was turning on, which it was. So we decided to see if the engine would even turn, we sprayed ether into the engine and cranked it and this is where it gets weird, it didn't turn over at all, no pops anything the engine never got off the starter, so that is where the quick test ended. Now we are going to tear into the engine but before we do we wanted to see if anyone had any suggestions on what might be going wrong or any ideas where to start. This is my daily commuting car so if the admins can keep this near the top for help that would be great. I love this car and the community that comes along with it long live the stang and hopefully mine will live again soon. Thanks Again
1994 Mustang GT vert
The easieat way to solve your problem is to follow this checklist, I promise.
This should be a sticky at the top of every 5.0 tech forum, as I see this question on a regular basis. Cranks OK, but No Start Checklist for Fuel Injected Mustangs Revised 26-Aug-2007 to add missing secondary ground on back of the engine. All text applies to all models unless stated otherwise. Note: 94-95 specific changes are in red 1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark. Most of the items are electrical in nature, so a test light, or even better, a voltmeter, is helpful to be sure they have power to them. No spark, possible failed items in order of their probability: A.) MSD or Crane ignition box if so equipped B.) Coil C.) TFI module D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking. E.) No ECC or computer power - ECC or computer relay failure 86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires 94-95 models only: EEC or PCM power relay in the constant control relay module. Look for 12 volts at the fuel injector red wires. F.) No ECC or computer power - fuse or fuse link failure 86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. 94-95 models only: 20 amp EEC fuse in the engine compartment fuse box. Look for 12 volts at the fuel injector red wires. G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown. 94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp fuse H.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. J.) Computer I.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch. See the following links for wiring diagrams... http://www.autozone.com/servlet/UiBr...3d8016713c.jsp for 79-88 model cars Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/g...3d80167158.gif Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/g...3d8016715e.gif Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/g...3d80167162.gif http://www.autozone.com/servlet/UiBr...3d8019595a.jsp for 89-93 model cars Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/g...3d8019595f.gif Computer/fuel pump/ignition wiring diagram, 91-93 cars http://www.autozone.com/images/cds/g...3d80195960.gif </title></head>"); newWindow.document.writeln("<body><div align='center'><img " + getWidth("yes") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>"); newWindow.document.writeln("<div align='center'><table><tr><td><FORM for 94-98 model cars 2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: A.) Moisture inside distributor – remove cap, dry off & spray with WD40 B.) Distributor cap C.) Rotor D.) Spark Plug wires E.) Coil weak or intermittent - you should see 3/8" fat blue spark with a good coil 3.) Spark at spark plug, but no start. Next, get a can of starting fluid (ether) from your local auto parts store: costs a $1.30 or so. Then pull the air duct off at the throttle body elbow, open the throttle, and spray the ether in it. Reconnect the air duct and try to start the car. Do not try to start the car without reconnecting the air duct. Two reasons: 1.) If it backfires, the chance for a serious fire is increased. 2.) On Mass Air cars, the computer needs to measure the MAF flow once the engine starts. If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t, then it is a computer or timing issue: see Step 4. Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure. 4.) No fuel pressure, possible failed items in order of their probability: A.) Tripped inertia switch – Coupe & hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter. Look for 12 volts at the Pink/Black wire on the fuel pump relay. C.) Clogged fuel filter D.) Failed fuel pump E.) 86-90 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. 91-93 models only Blown fuse link in wiring harness. Look for 12 volts at the Pink/Black wire on the fuel pump relay. The fuse links for all model years 86-93 live in the wiring harness near the starter solenoid. 94-95 models only: 20 amp fuel pump fuse in the engine compartment fuse box. Look for 12 volts at the Dark green/yellow wire on the constant control relay module. F.) Engine seem to load up on fuel and may have black smoke at the tailpipe. Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running. If fuel is coming out the vacuum port, the regulator has failed. Check the regulator vacuum line for fuel too. Disconnect it from the engine and blow air though it. If you find gas, the regulator has failed. 5.) Fuel pressure OK, the injectors are not firing. A.) A noid light available from any auto parts store, is one way to test the injector wiring. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing. B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too. D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on. E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold). F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors. G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage. On a 94-95 Mustang, probe the black/white and grey/white wires to measure the TPS voltage. It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit. 6.) Spark & fuel pressure OK. A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car. B.) Failed computer (not very likely) C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently). D.) Firing order off: HO & 351 use a different firing order from the non HO engines. HO & 351W 1-3-7-2-6-5-4-8 Non HO 1-5-4-2-6-3-7-8 E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT. F. ) Engine that has had the heads off or valves adjusted. Do a compression test to make sure the valves are not adjusted too tight. You should have a minimum of 90 PSI on a cold engine. __________________ got this from 95opal hope it helps if you haven't figured it out yet |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/161031-mustang-wont-start-please-help.html
| 94 Mustang Eec Relay - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | June 2nd, 2010 01:13 PM | |
Threads Similar to: Mustang Won't Start Please Help
| Mustang Won't Start Please Help | brad12 | 5.0 Mustangs | 6 | April 15th, 2010 11:51 AM |
| HELP: 89 mustang. 2.3 not sure where to start | sam89 | 2.3 Mustangs | 14 | February 1st, 2010 10:27 AM |
| 87 Mustang 5.0 won't start | jtillery | 5.0 Mustangs | 6 | November 26th, 2006 03:49 PM |
| 95 Mustang Won't Start | agrigar | V6 Mustangs | 9 | September 24th, 2006 08:18 PM |
| '90 mustang will not start. HELP!! | dkrch | General Tech | 11 | June 23rd, 2006 11:10 AM |
