02 GT
Airflow Dynamics of different intakes
Hey guys-
I'm hoping there is a CFM expert on here that can help me make sense of this: I'm looking at two possible combinations for a KB 2.1 blower intake system on a stock-block 2v. Both would use an 80mm MAF(stock) and a 75mm TB. What I want to know is which scenario is better for airflow performance? ![]() 1.) A 100mm tube from filter to MAF(80mm) > 100mm tube from MAF to TB(75mm). This is similar to a JLT type CAI, and has the most volume potential in the intake, however, the abrupt kneck-downs at the MAF and TB makes me think it might not be the smoothest FLOW. 2.) A 100mm tube from filter to MAF(80mm) > 77mm tube from MAF to TB(75mm). This one is like the Tunable Induction type CAI, and has a decreasing I.D. stepped at each compnent up to the S/C. I'm wondering if this would be smoother then the first one and actaully make better velocity/torque? The KB would be pullied at 9psi and both filter elements draw from the fender well. None of the pieces have been bought yet, if there is a better combination I'm open to it as well. Thanks-
![]() 02 2v 5sp- 9lb KB 2.1L I/C, 90MAF, 75mmStack TB, FLSFC's, Magnaflow C/B, NT555R's, MGW shift, Black Sabbath |
Threads Similar to: Airflow Dynamics of different intakes
| CAI and airflow sensor | moderndayviking | General Tech | 3 | February 11th, 2010 12:06 PM |
| 5.0 is Back: 2011 GT Leads Class With 412 HP, Fuel Efficiency, Chassis Dynamics | DarkCandy08GT | 2005 - 2010 | 50 | January 3rd, 2010 08:32 PM |
| Ground Dynamics SUCKS! | supermachone | Vendors | 8 | November 14th, 2007 01:57 PM |
| positive airflow | JASonic | V6 Mustangs | 24 | May 11th, 2007 09:29 AM |
| where does the airflow come from on 2004 | JASonic | V6 Mustangs | 1 | February 27th, 2007 04:03 PM |
