Focus fuel pump install question.
Old April 16th, 2010, 01:20 PM   #1
2001 Mustang V6
Warhorse01 is on a distinguished road
I know that this install is a simple drop in plug and play, but there is one thing I'm unsure of thats not addressed in any threads.
Do you need to swap the rubber vibration damper on your stock pump over to the focus pump or can you just leave the rubber vibration damper from the focus pump on it?
The reason I ask is because after close inspection, I noticed that the rubber piece from the focus will make the pump sit slightly higher in the basket, possibly restricting flow just a little bit.
For you guys who have done this install, what you did you do in regards to this? Thanks
Old April 16th, 2010, 09:39 PM   #2
Quick99's Avatar
1999 Mustang GT
Quick99 is on a distinguished road
I just installed the whole basket and swapped over the harness.
Old April 20th, 2010, 06:01 PM   #3
2001 Mustang V6
I'm not going to install the focus basket and swap over the harness when it's really unecessary because I can just use the stock one.
So can anyone who used their stock basket answer this question for me?
Which vibration dampner did you use in the stock basket? The focus one, or the stock mustang one?
Threads Similar to: Focus fuel pump install question.
SVT focus fuel pump oh2swapped 99-04 7 August 2nd, 2008 04:05 PM
SVT Focus Fuel Pump gooberhead320 The Clubhouse 16 May 22nd, 2008 02:49 AM
Getting A Focus Fuel Pump Uncle Humjaba 96-98 19 January 1st, 2008 09:23 PM
Focus SVT Fuel Pump install gsjohnson 99-04 5 September 16th, 2007 02:40 AM
