Vortech PCV 03-04
Old June 1st, 2010, 12:43 PM   #1
Stanginsean is on a distinguished road
Vortech PCV 03-04
I've been in the process of installing my V2 setup on my 03 GT and this has been quite a long task because of minor set backs, however I am completely done EXCEPT when I had purchased everything from Vortech with the assistance to the $1500 Supercharger build thread, it did not note for 03-04 you need a PCV Bypass Assembly. I've since ordered the part however it won't be here for about 3 days. What exactly does it do and how important is it? Im wondering if I can atleast start up my car and check for leaks; Vaccum/Oil/Fuel and not drive it with just the stock PCV.
This is the Part SuperchargersOnline.com :: Product: Vortech PCV Bypass Assembly for 2003-2004 Ford Mustang with 4.6L
Old June 15th, 2010, 12:48 AM   #2
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
I installed my used V1 a month ago and didn't use no pcv bypass. I'm venting the driver side valve cover to an oil catch can with breather, but the pcv with hose connection to plenum stayed the same.
Threads Similar to: Vortech PCV 03-04
Pics of my Vortech - Need help from you Vortech guys!! stanglifemike 2005 - 2010 29 September 12th, 2009 10:52 PM
PCV??? wishIhada5.0 99-04 0 February 25th, 2009 02:04 AM
PCV mmvi V6 Mustangs 23 December 28th, 2007 11:38 PM
PCV RyanGT 99-04 9 December 18th, 2007 05:03 PM
PCV Bill 5.0 Mustangs 2 August 20th, 2006 03:55 PM
