Friction additive?
Old April 10th, 2006, 12:29 PM   #1
OTreborO is on a distinguished road
Friction additive?
I read somehwere about possibly having to add some kind of Ford miracle stuff if my rear gear oil if my differentional was a certain kind to help reduce friction???
How do I determine if I need this wonder drug
Old April 10th, 2006, 12:49 PM   #2
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
friction modifier is used for the protection of the clutches in limited-slip differentials, there are also aftermarket companies that make this stuff too, like redline.
Old April 11th, 2006, 02:06 AM   #3
BULLITT's Avatar
BULLITT is on a distinguished road
Send a message via AIM to BULLITT
If its the first time filling up the posi. Like if it was never used add the 4 oz bottle. If your just putting new gears in or changing the fluid allyouneed is like 2 oz half the bottle. They say like my 03 cobra posi unit. I only need it on the initial fill. After that i dont needot add it anymore. If im just changing the gear fluid.
And its not really to stop friction to much. Its to help unlock the posi clutches so you can make turns whithout hearing the tires chirp. thats all.
I dont add any on just chaging fluid. To much if itand sooner or later ull get one wheel peels when it gets hot in their.
Old April 11th, 2006, 01:26 PM   #4
yes too much will cause issues but it has to be A LOT. Synthetic fluid is also more forgiving when it comes to lack of modifier and some fluid has the modifier already added. I always add 1-2 bottles everytime I remove a rear cover. Not like Ford doesn't have a problem here lately with binding diff clutches.
88 Mustang Coupe
www.rickscarcare.net
Old April 11th, 2006, 02:18 PM   #5
Is there a way to tell which rear I have.
Is there a way to tell which rear I have. I didn't think I saw any cluthes when I took the gasket off and changed the hypoid oil.
Old April 11th, 2006, 02:48 PM   #6
if there was a small metal tag under one of the cover bolts, look on it and you'll see a # that says 2L73 or 3L08. If the L is present it's a limited slip. If there is just a blank space where the L is in the example above, it's an open diff.
88 Mustang Coupe
Old April 11th, 2006, 02:52 PM   #7
mdvaldosta's Avatar
11.47@120.58
If you've got a 4cyl car then it comes stock with a 7.5" open differential. All the 5.0's from 86 up (maybe 85 I can't remember) whether LX or GT came with an 8.8 trac loc.
Old April 11th, 2006, 04:51 PM   #8
vfast will become famous soon enough
if you use redline gear oil it has it in it already
Threads Similar to: Friction additive?
good additive WilltheThrill General Tech 8 August 9th, 2007 09:46 PM
Should I add friction modifier with Valvoline gear oil 96BluePony1261 Modular Mustangs 5 March 1st, 2007 06:55 AM
Friction Modifier? 4.6gtmarine 99-04 2 November 3rd, 2006 01:23 AM
need help on next additive Brianzeke007 V6 Mustangs 2 September 28th, 2006 12:48 AM
