Vortech IAT Correct?
Old June 8th, 2010, 03:47 PM   #1
Stanginsean is on a distinguished road
I just did virtually the last step in my Vortech install and it was adding an IAT since mine(03) had it in the stock MAF.Im almost certain we connected the 2 correctly. We cut wire 1 & 6 from the connector and soldered them to the 2 prongs on the sensor.
My question is how will I know if we connected the wire to the correct prong or if we have them backwards. Or if they have a good enough connection. Will I get a Check Engine if its not connected correctly? Any other way to know for sure? I looked on other peoples setup and and im almost certain its done right.
Old June 8th, 2010, 04:00 PM   #2
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
I'm wondering the same thing actually
Do the Right Thing, Cook. ~Zip.
Old June 8th, 2010, 04:29 PM   #3
Hopefully someone can help us
Old June 8th, 2010, 04:43 PM   #4
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
You want to get a 03 Lightning IAT sensor with pigtails...
The outer 2 gray wires are correct...
The preblower IAT's will always give false readings...
The order doesnt matter for which wire where...
Facebook
Google+
Old June 8th, 2010, 04:55 PM   #5
Thanks,however since I didn't buy the pigtails and just soldered it doesn't matter which one is connected to which on the sensor??
Old June 8th, 2010, 04:59 PM   #6
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Did you buy and 03 Lightning IAT? Not talking about the IAT that comes with the kit...
Facebook
Google+
Old June 8th, 2010, 06:48 PM   #7
Yeah I bought a seperate lightning IAT
Old June 9th, 2010, 10:35 AM   #8
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
then yes you are fine...Make sure it goes after the blower and before the throttle body...
Facebook
Google+
Old June 10th, 2010, 09:21 AM   #9
I have it in the discharge tube after the blower & also before the TB, but im wondering how will I know if the soldering made a good connection onto the sensor. Will I get a check engine if its not reading the sensor? How will I know if the sensor is getting a reading? Because I read in another thread it could cause detonation if not installed correctly. So i'm a bit worried.
Old June 10th, 2010, 01:29 PM   #10
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
I will take a picture of mine when I get home and post it if that will help you...
Facebook
Google+
Old June 10th, 2010, 08:48 PM   #11
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
If you have a handheld tuner plug it in and datalog the IAT once you get it hooked up to see what kind of readings you're getting.
Old June 11th, 2010, 12:54 PM   #12
Unfortunately I do not have a handheld. Only a chip.
Old June 11th, 2010, 06:00 PM   #13
If you know anyone with a tuner you can use theirs to check it out.
Also some of the higher end code readers will do the same thing, maybe a local auto parts store could take a look for you with theirs.
Old June 12th, 2010, 12:44 PM   #14
Okay thanks. Would it throw a check engine though? I've turned it on let it run a bit and got a check engine, However I know i'm going to get 1 because I got a base tune and it didn't turn off my O2 sensors for my exhaust, so that very likely could be triggering it. Gotta get a scanner and find out for sure. But is it possible itd give me a check engine?
Old June 12th, 2010, 03:33 PM   #15
I would think it'd throw a P1112 if it wasn't hooked up.
How are you getting this tuned?
Old June 13th, 2010, 02:33 AM   #16
Yep as soon as I make sure its alright to drive, since the drive is ~30 minutes and on the highway.
Old June 13th, 2010, 03:37 AM   #17
Hopefully it all works out for you.
I ended up driving my car ~1000 miles after my procharger install without a tune. Just stay out of boost as much as possible and you should be fine.
Old June 13th, 2010, 09:54 PM   #18
Oh alright thanks, yeah just ran the code and im getting P0453, "Evaporative Emission Control System Pressure Sensor High Input", believe its something with the install of the fuel pump. So the engine seems to be fine, so going to check that out and get it over to my tuner. Thanks
Threads Similar to: Vortech IAT Correct?
IAT and Vortech blackstang014 96-98 2 February 26th, 2010 03:10 AM
IAT sensor bandity2k00 99-04 8 October 1st, 2009 12:14 AM
What should my IAT be? Dolbs4082 99-04 6 May 27th, 2009 12:39 PM
Where is IAT on 95 GT? JesusOnIceSkates 94-95 4 July 17th, 2008 09:09 AM
IAT coreyfitz 94-95 6 March 15th, 2007 11:31 AM
