![]() iTrader: 1 reviews
Transmission help!
Okay, so i bought 2 bad T-45's that will equal one good one. The case is cracked on the good one, and the good case is on the one with a bad 4th gear. So what would be the easiest way to do this? can i just swap out the shafts or do i need to swap everything over?
or am i better off spending $200 on a rebuild kit and do it all? the gears in the other one are okay, so i assume i should be fine just swapping them over?
Threads Similar to: Transmission help!
| Transmission | zinc02GT | The Clubhouse | 7 | September 20th, 2009 09:18 PM |
| 95 gt transmission | usmc95gt | 94-95 | 10 | February 5th, 2009 02:50 PM |
| Transmission Help! | 1sl0w88 | 5.0 Mustangs | 7 | February 2nd, 2009 10:53 AM |
| Transmission???? | flamed 98 gt | 5.0 Mustangs | 34 | January 28th, 2009 09:17 AM |
| Need New Transmission. ?which? | Draidin | 99-04 | 15 | December 27th, 2008 10:48 AM |
