Clutch Quadrant, Firewall Adjuster, Height Adjuster Install w/pics
LinkBack (1) Thread Tools
Old July 5th, 2010, 07:57 PM   1 links from elsewhere to this Post. Click to view. #1
June 2010 ROTM
Serlin's Avatar
2000
Serlin is a jewel in the roughSerlin is a jewel in the roughSerlin is a jewel in the roughSerlin is a jewel in the rough
Thumbs down
I just did this mod and thought I'd take a stab at documenting it for y'all.
I always thought my clutch pedal was way to high. So I went and got the UPR Quadrant, Firewall Adjuster and Pedal Height Adjuster.
Here's the deal:
The install is pretty straight forward, although it did take me a few hours getting it adjusted correctly.
Basically:
Remove the driver seat. Makes it a million times easier to get under the dash.
There are 2 pins that hold the clutch quadrant on. Pull those out, and pull the quadrant off.
Pull the cable out through the firewall.
On the end of the clutch cable, there is a big rubber piece, and mounting bracket. With a razor blade, cut the tips of the white plastic piece off and slide the rubber piece off. It doesn’t get used again.
Mount the firewall adjuster where the old one was. Its kind of hard to get the screws in, but its doable.
Put the clutch cable through the firewall adjuster and back through the firewall.
Now, it depends on your clutch cable, where to put the end of the cable. I tried the top mounting point, but it made the cable to tight, and engaged the clutch right at the top.
I ended up using the middle mounting point which was perfect.
Put the quadrant back on and put the 2 pins back in.
Next install the clutch height adjuster. Hard to explain, but hopefully the picture shows exactly how it goes. Then just adjust the screw in or out to adjust the height of the pedal.
Use the firewall adjuster to adjust where the clutch engages. Mine is about 2 inches above the floor, and fully engaged well before the pedal is all the way out.
Overall I am very happy with this mod. Now my pedals are almost even. Clutch pedal is still about an inch higher than the brake pedal, but overall, 100 times better.
HPDE Instructor
PCA, HOD, Track Guys, ERME
www.RaceCarTowHooks.com
My Track Videos http://www.youtube.com/user/Msirlin
My Garage page: http://www.moddedmustangs.com/forums...-member-17090/
Old July 25th, 2010, 07:24 PM   #2
fonypony is on a distinguished road
This article with pics really helped me out. Bought a BBK kit and the instructions, well sucked. My 1990 GT's plastic quadrant has a few broken teeth. I like that the slf adjuster is eliminated.
Thank you
Old July 25th, 2010, 07:30 PM   #3
June 2010 ROTM
Serlin's Avatar
2000
You are very welcome.
HPDE Instructor
Old January 4th, 2011, 07:33 PM   #4
FR999's Avatar
1999 Mustang Cobra
FR999 is on a distinguished road
Thank's for posting this how to, it was very helpful to me as a preview.
Old January 18th, 2011, 12:02 AM   #5
94bonestocker's Avatar
1983 LX Hatch
94bonestocker is on a distinguished road
Nice write-up!
Just your everyday Non-5.0L LX Fox
Old January 18th, 2011, 07:23 AM   #6
01KnightRiderGT's Avatar
2001 Mustang GT
01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about
Send a message via MSN to 01KnightRiderGT
Good job!!
Black Stang Member #13
315's Crew Founder
My Track Videos
Old February 7th, 2011, 08:58 PM   #7
ItsChip is on a distinguished road
just followed your steps for this and got everything in just fine... when i went to back out of my garage i immediately smelled burning clutch. i took up some of the slack and tried again and the same thing happened. is it the adjustment or something else?
Old December 4th, 2011, 09:56 AM   #8
13.91 @ 102.04
02'TrueBlue will become famous soon enough
So wait, I was under the impression that I have to do something under the car...Is this really all it entails?
TRUE BLUE CREW MEMBER #6
Old January 10th, 2012, 11:47 PM   #9
2003 Ford Mustang GT
14.871
Skoolhater is on a distinguished road
Thanks, I was a bit nervous about putting my steeda quadrant and adjuster in, but you made it seem pretty simple, can't wait to get it all in.
Old January 14th, 2012, 10:01 PM   #10
slider of slithery snake!
cobra-drifter's Avatar
1996 SVT Mustang Cobra
UKNOWN, i drift
cobra-drifter is on a distinguished road
I want to get one of these for my 96 Cobra, is any brand better or easier to work with than the other?
Cobra is for sale!!! Look here!!! http://atlanta.craigslist.org/atl/cto/2851281275.html
Old February 25th, 2012, 04:00 PM   #11
Look Ma! My First Post!
paintb8 is on a distinguished road
Hi All, brand new to moddedmustangs. Thanks for having me.
I just purchased a '95 GT that has a MM quadrant and firewall adjuster installed. The clutch engages as soon as the pedal comes off the floor. I would like to get the clutch engagement to take place further out in the travel but my firewall adjuster is almost completely backed out of the firewall. I am afraid there won't be enough threads engaged If I try to back it out any further. Any thoughts?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/173003-clutch-quadrant-firewall-adjuster-height-adjuster-install-w-pics.html
more clutch issues - Page 2 - MustangForums.com This thread Refback December 25th, 2010 09:26 PM
Threads Similar to: Clutch Quadrant, Firewall Adjuster, Height Adjuster Install w/pics
Steeda Clutch Adjustment Quadrant, Cable, Firewall Adjuster. fallstar01 Parts 4 August 26th, 2010 01:51 PM
UPR firewall adjuster speed clutch quadrant shadowgames81 99-04 15 August 4th, 2008 05:33 PM
Steeda Double Hook Quadrant and Firewall Adjuster Install... ChrisJ 99-04 8 May 1st, 2008 09:42 PM
Quadrant,firewall adjuster, adjustable clutch cable silver99gt 99-04 2 March 10th, 2008 11:21 PM
Clutch quadrant and Firewall adjuster ujslost 96-98 4 April 15th, 2007 07:39 PM
