aluminum driveshaft
i know that the aluminum driveshafts are stronger but i am curious to the performance. how much would it reduce your times in say the 1/8 or 1/4?
how: becasue it weighs about 15 pounds lighter than the factory driveshaft and anytime you reduce rotating mass, it frees up more power to get to the ground
o sorry read it wrong, probably not really gonna be a noticable difference but you engine will rev a little quicker
thanks just curiuos about that. I know that it revs a little quicker i was just wanting to compare the gains to say a cold air or other performance mods far as acceleration.
You are not gonna feel anything.. Its like when you were a kid and you get a new pair of sneakers and you swear that you can jump higher run faster... Like they said there is a performance to be had but its minimal..
you wont notice the gain, but i think its definately worth buying!
http://www.cardomain.com/ride/2461223 1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon! |
wait why's it worth buying when you wont notice any difference??
If you aren't first.....your last!
Because its 10x if not more stronger than stock. The U-joints are stronger and there is less rotating mass that is less strain on your drivetrain.. if you have hardly and mods or mild mods dont bother but if your car is makin 300+ hp get it...
You most likely won't notice anything but like Stangzilla said, it is stronger. It is also about 5lbs less rotating weight. Every little bit helps.
1993 Notch, 1988 Notch
Less rotating mass+ the advantage of harmonics, which is something few notice but the difference is there, for the same reason people have the stock D/S's balanced. Plus you get the ability for the shaft to flex to a small degree with the flex of the vehicle which is something you do not get from steel quite as well. My $.02 on the dead horse.
Threads Similar to: aluminum driveshaft
| aluminum driveshaft | 03TropicGt | 99-04 | 27 | November 4th, 2007 01:16 AM |
| Aluminum Driveshaft | homebrewed | 5.0 Mustangs | 16 | March 3rd, 2007 01:01 AM |
| Aluminum Driveshaft | PONYBOY14 | General Tech | 2 | February 3rd, 2007 01:30 PM |
| aluminum driveshaft | 97TunedMustang | V6 Mustangs | 0 | June 21st, 2006 02:14 AM |
| aluminum driveshaft | kbstang | 99-04 | 7 | March 19th, 2006 02:44 AM |
