about lowering...
exactly how do you go about lowering a 94 'stang...do I just need to get lowering springs on their own or do i need one of those suspension kits that has shocks and dampers and everything...if that even made sense, I don't really know what i'm talking about!
'88 LX body '91 GT D/T
8.7 in the 1/8th
depends on how much ya wanna lower it. a set of C/C plates aren't always a necessity, but are great to have in the future. 1.5" is about all you will wanna go. what brand/kind of springs are you gonna put on? street, drag, Eibach, Steeda? SPC manufacturing makes adjustment hardware and is failry reasonable on price. as for dampers, an upgraded set will net you the most from your drop. KYB, Lakewood, and Strange make force adjustable replacements. there are a few other manufactures out there that make adjustables, those are just a few.
Now that you are totally confused, send me a PM if ya want more info
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
#3 | |
Get a Eibach prokit. 1.5" drop and all you have to do is change the springs and get an alignment.
8.7 in the 1/8th
are you being facious or truthful?
#5 | |
#6 | ||
#7 | |||
huh...stock springs already have a rough enough ride for me, I was kinda hoping to get something that would give me a smoother ride. But I guess I can't do that if I'm gona lower it eh...or what..
i have steeda sport springs in my 94.. dropped it down nice & all i needed was an alignment...
http://www.cardomain.com/ride/2461223 1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon! |
#10 | |
#11 | |
Re: about lowering...
In a stock configuration the lever ends of the swaybars are mounted so that they are parallel with the lower control arm bushings. This is the ideal positioning of the lever ends for maximum sway restriction. Once the car is lowered by using aftermarket springs the swaybar levers are no longer parallel - thus causing altered geometry of the suspension and decreased sway resistance.
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
#12 | ||
8.7 in the 1/8th
Neckbonekat is spot on about the Eibach springs. The Pro kit is a progressive rate spring. What that means, and try to bare with me here, is that over potholes and washout and all other manner of road imperfections, they will compress very similiar to an OEM spring. When things get a lil more intense and they are pushed furher, they will stiffen in a progressive manner. That means they won't just stiffen all the way at once and make you feel like you're ridin' in a grain truck.
#13 | |||
using the prokit (1.5"drop) on my coupe, I solved the end link problem by cutting 1.5 " off of the spacer tube and adding it back on top under the nut. worked for me .
SAVE GAS & KICK ASS = BOOST !!!! |
Threads Similar to: about lowering...
| Lowering | scxc15 | General Tech | 21 | March 23rd, 2007 11:17 AM |
| lowering kit | 96DropTop | General Tech | 4 | January 13th, 2007 05:24 AM |
| lowering | stanged out | V6 Mustangs | 3 | January 10th, 2007 03:01 AM |
| Need help About lowering my car | dblindberg | 2005 - 2010 | 0 | January 3rd, 2007 01:25 AM |
| lowering | charlesnash | 2005 - 2010 | 27 | December 22nd, 2006 12:15 AM |
