Fuel Problems
Old September 2nd, 2010, 11:06 PM   #1
Look Ma! My First Post!
1994 MUSTANG GT CONVERT
JERSEYGIRL is on a distinguished road
Fuel Problems
Hey Everyone My Mustang Doesnt Want To Start And Im Sure Its A Fuel Problem. Ive Changed The Fuel Filter And Still Not Starting? Should I Try Changing The Pump Or Could It Be Something Else??? Please Help!
Old September 7th, 2010, 12:33 AM   #2
Serpent's Avatar
86 GT 5.0
Serpent is on a distinguished road
Do you hear your fuel pump priming the enigine when you first turn the key? I just had my fuel pump relay burn up on me it was ugly. It was under my seat. Once it went out my car wouldnt start and it was clearly not getting gas. The relay was toast.
Old September 8th, 2010, 12:09 PM   #3
Trick Tuners's Avatar
KB'd GT
Maybe describe it better. Does it continue to crank without firing? What if you give it some throttle on crank? Does it ever "try" to start then stumble and stall?
Threads Similar to: Fuel Problems
Fuel problems i think? 97 Mustang 96-98 8 August 5th, 2010 05:01 AM
Having fuel problems mjacobs321 2.3 Mustangs 8 July 10th, 2010 11:39 PM
still fuel problems viperlocc 5.0 Mustangs 0 April 19th, 2009 11:38 AM
Fuel problems....Any help? Casper98GT 5.0 Mustangs 5 April 21st, 2008 01:23 AM
HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? 1slowhatch 5.0 Mustangs 0 April 21st, 2007 07:48 PM
