1998 Mustang V6
batter corrosion
so i always have to jump my batter and havent had the chance to get it tested cause i dont want to be driving around with a bad battery, so i was going to take it out today when i noticed that there corrosion and grease all over the clamps and terminals so when i unbolted the clamps the lines cant come off. whats the best way to clean them up so i can get the lines off?
1998 Mustang V6 -BBK 56mm throttle body -K&N CAI 1982 Mustang GT -8.8" positrac rearend -Tremec T5 swap -Shelby high rise intake -Edelbrock performer carb -dumped Flowmaster exhaust |
1997 Mustang GT
pour a can of coke on the terminals until the corrosion is gone and then wipe them off. And if you want to keep them from becoming corroded take a penny and silicone it between the 2 terminals. U will need a new penny from time to time but its better than having corroded terminals
Using coke will end with stickiness over the place, you can very cheaply get battery terminal cleaners from auto part stores.
To prevent it, you should use lithium grease on the positive terminal, negative should be fine. |
1999 Mustang V6 ~For Now~
little late, but wd-40 is a great way to get rid of it. and should be in everybody's garage
Threads Similar to: batter corrosion
| Help! Major Corrosion! | getchapull | V6 Mustangs | 2 | September 20th, 2010 07:41 PM |
| batter meter jumpine around | navy-ad3 | 5.0 Mustangs | 1 | July 6th, 2010 02:12 PM |
| battery terminal corrosion | RyanGT | 99-04 | 7 | July 17th, 2008 07:35 PM |
| Batter light | AnFking6908 | V6 Mustangs | 1 | April 11th, 2008 11:47 PM |
| Corrosion | whtpny | General Tech | 7 | April 3rd, 2008 12:53 AM |
