Creaking noise during steering
Have a creaking noise when I turn the steering wheel to the left only. I have a 2003 mach1. It appears to be coming from the passenger side. I think its the rack & pinion. Any feed back will be most helpful. Car has only 12,000 miles never driven hard or on rough roads and driven only by one driver. The noise occurs both idle or moving.
noise
I had a noise like that at 24k on my 01 cobra. I had to replace some outer joints forsome reason. But the noise went away after that. Almost as if the joints had become dry at close to lock.
john |
i kinda have the same problem. mine isn't very loud and it doesn't do it all the time. i was told it was my outer ball joints. i bought the, but haven't installed them yet.. they run about $45.99 a piece from advanced.
Ford TSB 05-14-3
SQUEAK/CREAK NOISE FROM STEERING RACK WHEN TURNING FORD: 2002-2004 Mustang Some 2002-2004 Mustang vehicles may exhibit a squeak or creak type noise when turning. Replace Power Steering Gear Tube Brackets Tighten the steering gear mounting fasteners to 52 lb-ft (70 N•m). PART NUMBER E5DZ-3K620-A Bracket - 2 required |
wow, cool.
Thanks all for the info..Don,t feel to worried now, specifically with the reply post that Ford has put out a TSB on it...Take care all..
Threads Similar to: Creaking noise during steering
| Creaking noise?? | auburntiger7231 | 99-04 | 10 | October 9th, 2007 10:11 PM |
| steering noise | Blackbeauty v601 | V6 Mustangs | 10 | August 10th, 2007 07:24 PM |
| Steering Noise | xx9gt6xx | 96-98 | 10 | June 18th, 2007 11:37 AM |
| Steering Shaft Noise | Black Bullitt | 99-04 | 2 | January 18th, 2007 09:00 AM |
| Noise When Steering | MikeD | General Tech | 13 | October 13th, 2006 08:04 AM |
