1987 GT
13.19 @ 107.02 (street tires)
Supercharger belt tension correct??
How tight should a supercharger belt be? I have a Vortech V3 on my 87 GT 5 speed, and pulled the bracket as hard as I could with one hand while tightening it in place. Belt goes from the blower to around the double pulley crank and is tightened by a tensioner pulley in the middle. Is this tension correct, too tight, too loose???? I didn't use any prybars or anything like that. Couldn't find anything in the instructions that came with it saying 1/8" deflection, as tight as you can, ... ,etc. Thanks.
'00 V6 Procharged Mustang
Sounds about right, if anything on the loose side.
You really want them to be tight but not so tight that they're going to create a ton of heat and shread themselves. When I replaced mine on my supercharged v6 it took two people and is very tight. No problems after 10k miles and it still looks like new.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). |
Threads Similar to: Supercharger belt tension correct??
| Seat Belt tension | KalSaint | 94-95 | 0 | June 2nd, 2010 03:44 PM |
| how to tension the belt? | crappy_head | 99-04 | 8 | November 29th, 2008 10:06 PM |
| belt tension problems | jtyson8602 | 5.0 Mustangs | 20 | November 16th, 2008 11:01 PM |
| eaton supercharger with CORRECT manifold on 2v | ajm | Modular Mustangs | 4 | June 6th, 2008 09:37 PM |
| Supercharger belt | rennyboy | General Tech | 3 | April 12th, 2007 06:28 PM |
