Tire diameter/ABS and Trac Control?
Old October 29th, 2010, 11:42 PM   #1
rsb5772 is on a distinguished road
Does anyone know if using a rear tire with a height of 28.7, and front of 27.6, would cause problems with the anti-lock braking or the traction control, due to them spinning at different speeds? I'm planning on buying 315/35/20 and 275/35/20 tires, but could go 275/40/20 if it would cause a problem. Thanks.
Old November 15th, 2010, 07:50 PM   #2
2000 gt
Everett will become famous soon enoughEverett will become famous soon enough
i think that is what engages your trac control ....when it senses the rear tires spinning more than the fronts....i read a write up on this not too long ago....try searching the threads....and some of the guys on here are amazing so with any luck one of em will notice and post for you...
Black and White Crew
Crew Member # 3
centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie
Threads Similar to: Tire diameter/ABS and Trac Control?
trac control removal sidewaysgt 99-04 15 February 23rd, 2010 05:25 PM
Tire diameter size differences and Traction Control Gray Ghost GT 2005 - 2010 11 April 29th, 2009 07:38 AM
Lower control arm bolt diameter? Someone refresh my memory... C MY 4D Modular Mustangs 0 March 15th, 2009 02:50 PM
Tire diameter travis_afx 99-04 2 March 30th, 2008 05:22 PM
tire diameter and drive ratio 99mustang232 General Tech 2 December 6th, 2005 08:59 PM
