Discussing noise on right rear question in the General Tech Forum. On my 94 gt I hear a real expensive noise in the right rear while ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2001 Mustang Cobra
noise on right rear questionjohn |
Sounds like the brake pads may be moving around in the caliper mount. Make sure all the little anti-rattle clips are there and in good shape as well as make sure the rotors aren't grooved.
88 Mustang Coupe 2006 FFW Richmond True Street Runner-Up www.rickscarcare.net http://img146.imageshack.us/img146/2158/ricksadql2.jpg |
That's not good if you only hear it and know it's expensive....
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
2001 Mustang Cobra
The little clips are there and appear to be ok. The rotors show a little grooving but are still pretty smooth to the touch. I have experienced an intermittent lack of brake power. When aplication of the pedal sometimes the pressure is there by way of pedal feedback but not as much brake power to stop. I recently had a similar happening in the 01 cobra but the new rear calipers and pads seem to have fixed it. The noise on that car is getting worse but I now know it may be a weld that has broken, gotta find out soon. The gt will get all new pads shortly and I may go ahead and get a set of rear calipers just as a preventative measure. Gonna order the pads 2 d.
1. sometimes rotors and pads can get too smooth which is called glazing and they make noise that way so if the rotors are as smooth as glass that means they are glazed. if they are you might need to sand them a little.
2. you could have a warped rotor 3. you could have loose slide pins. hopes this helps
http://i46.photobucket.com/albums/f1...achine_124.jpg my vehicles: 1996 Mustang v6 232 ci 1969 F100 stepside inline six 300 ci www.mooresvilledragway.com www.shadysidedragway.com |
Threads Similar to: noise on right rear question
| Noise From Rear End | mavssteeda | Drivetrain | 9 | April 2nd, 2008 12:51 AM |
| Noise from rear - vid | tomzac | Drivetrain | 1 | October 8th, 2007 10:12 AM |
| rear end noise | dirg5 | Suspension | 6 | July 18th, 2007 10:41 AM |
| rear end noise | mustangboy8909 | 5.0 Mustangs | 13 | February 24th, 2007 04:46 PM |
| noise at rear-end | cobraetti | 5.0 Mustangs | 3 | January 15th, 2007 04:30 AM |
