Detaching cylinder question....
Old November 17th, 2010, 09:56 PM   #1
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
sikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to behold
Ok, so my top has not been working for a while, pretty sure it's the motor that went out, but could be the cylinders. I dunno.
Anyways. I've been just manually putting it up and down, but since the cylinders are still attached, it's crazy hard to lift up, because the cylinders lock without the motor pumping.
Question is, if I detach the cylinders from the top, will anything come out of alignment. The hope is to make it so I can manually put the top up and down without the need for two people. I just wasn't sure if the attachment point at the cylinder was a major anchor point that's going to make my top get all out of wack for being detached.
Cliffs: If I detach the cylinders will the top be able to go up and down manually?
MM Cobra Club #66
Threads Similar to: Detaching cylinder question....
Quick Question/Cylinder Numbers.. HorsepoweR 4V / SVT 1 June 18th, 2009 11:21 PM
Cylinder Head Question burin_rubber V6 Mustangs 8 April 10th, 2008 07:41 PM
Cylinder Head Question powersrj 4V / SVT 5 April 9th, 2008 12:42 PM
Cylinder Heads question Vinyl66 5.0 Mustangs 29 October 30th, 2007 09:56 AM
Cylinder Question charlesnixon Classic Mustangs 3 February 26th, 2007 04:44 PM
