Discussing '96 V6 swap for 2003 V8 in the General Tech Forum. Hello, I have an idea I want to bounce off anyone who will answer. I ...
Old April 12th, 2007, 11:19 PM   #1
Hello, I have an idea I want to bounce off anyone who will answer. I have a '96 mustang with a 3.8l v6. The 6 blew a head gasket and the head bolts are seized. I have a chance to get a hold of a 2003 4.6l v8 with all accessories, computer, harnesses, 5 speed trany with clutch, pedals master and slave cylinder. I know I will also need to replace the radiator, rear end and get a new exhaust system. What I need help with is will the stock motor mounts from the 03 v8 work or do I need the ones for the '96?
the car is now an automatic will the clutch pedal assembly bolt into the car(I know I will need a new console). Will all of my stock gauges work with the '03 computer and harness. Do I need to put a k-brace under the hood?
enough bablbing for now I am still in the planning stages and I am a Chevy guy by nature but I love my Stang and wanto learn more. Any advice, tips, or comments would be welcome and appreciated.
Old April 13th, 2007, 01:04 AM   #2
MustangMatt96GT's Avatar
13.023@103.46 @ 5800 FT
You will need a different K-member from a 96-98 GT! And you might beable to get the gauges to work but I have no clue and for the clutch assembly it should just bolt right in! Also the K-brace is not needed and many of the 99+ dont have them!
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Old April 15th, 2007, 08:56 PM   #3
I just found out the motor is from a 2000 gt not an 03. Is the radiator for a 3.8 and a 4.6 the same. how about the drive shaft , is it the same? Thanks for your input.
Threads Similar to: '96 V6 swap for 2003 V8
Will a 2003 Mach1 Strut Tower Brace fit my 2003? rcicu V6 Mustangs 4 April 15th, 2008 09:39 PM
2003-96 head/cam swap KaskaB 96-98 5 November 12th, 2007 01:55 AM
2002 GT VERT / 2003/04 MACH 1 Engine Swap JBasco20 Modular Mustangs 4 September 24th, 2007 05:41 PM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
new here, wanna swap exhaust on 2003 Mach01 WhoIsLion 99-04 9 October 19th, 2006 10:59 PM
