any hints on how to get the springs compressed to fit back
Old May 5th, 2006, 04:26 PM   #1
OTreborO is on a distinguished road
The rear was a breeze, didn't have to do a thing, but the front is a bit harder, looks like you have to partially compress the springs and then put them in, I was hoping I could just put then in, and then use a jack under the control arm to rasie/compress the spring. It is difficult to work a spring compressor in a good location to be able to fit the tight space of the control arm
Old May 5th, 2006, 04:39 PM   #2
mdvaldosta's Avatar
11.47@120.58
Remove the swaybar link, and tie rod, lower strut mount bolts and push the a-arm down with your foot. Put the spring in and raise the a-arm with a jack, once up, connect everything else back. Takes me about 15 minutes per side to change springs.
Old May 8th, 2006, 12:59 PM   #3
Thanks :-) I should of read your post before I did it, I used a spring compressor, and basically did what you did, and it took me about 2 hours per side, and I had to basically stand on the fender and hump it, lol, to get the strut to bolt back into the top hole. I love my car, but this humping shit has got to go....................... :-P
Old May 8th, 2006, 01:11 PM   #4
00SoSlow's Avatar
00SoSlow is on a distinguished road
Send a message via AIM to 00SoSlow
Old May 8th, 2006, 01:28 PM   #5
Yes
Originally Posted by 00SoSlow
Yes, your Avatar was what I looked like :-)
Old May 8th, 2006, 01:38 PM   #6
00SoSlow's Avatar
haha well congrats u got it back in
Old May 8th, 2006, 01:52 PM   #7
Oh by the way
Thanks,
I am doing a 4 cyl to v8 conversion, and the donar car's springs/struts are back together, now for the real car, it doesn't have a engine, and that weight really helps when trying to get it back together
Oh, by the way
Go Pack Go:
My Son and I drove 16 hours to go see The Packers on Christmas day this year. It was a blast, and the stadium is awesome.
Old May 9th, 2006, 12:02 AM   #8
00SoSlow's Avatar
yea the stadium is awesome, but the team sucks ass lol... with that nice stadium we need a winning team... one plus would be let favre go.... hes not a team player, get someone new in there
Old May 9th, 2006, 10:20 AM   #9
Ugh............................................... .........
I am having a hell of a time getting the v8 springs to go back into the 4 cyl car: The engine is out of the 4 cyl car, which may be causing a lot of the problems????? I currently have the spring installed on the drivers side, but can not get the strut to seat home. I was going to try to put the tire on the spindle and lower the car and press down hard on the fender??
Any hints??? Suggestions??? Should I go back to the 4 cyl springs? I have already put them back into the donar car, but I can remove them, or just buy a new set of 4 cyl springs
Sore/ tired/ frustrated/wondering why I ever started this project :-)
Old May 10th, 2006, 12:20 AM   #10
00SoSlow's Avatar
don't give up tho man... it should be a great car when ur done
Old May 11th, 2006, 12:13 PM   #11
Works a lot better if you do it the right way
I found out that if you try to put the dust cover on the strut first, then a bushing, then the strut tower bracket, then another bushing that it is really hard to get it to work:
But if you put on a bushing first, then the dust cover, then the strut tower bracket it goes much easier:
I learned this after scratching my head, wondering why I was an inch short.... I wonder that alot, but that is another story............
I took the donor car strut apart just to see what was going on, and found the problem.
One other note: The strut tower brackets are different in the 89 4 cyl vs the 90 8 cyl. I also found out that the brake line locking tabs for the front brakes are different for the v8 vs the 4 cyl. Freaking awesome :-)
Old June 30th, 2006, 10:29 AM   #12
prostangs is on a distinguished road
we always use heavy duty zip ties - use several that way when you get spring where you want it all you have to do is cut the zip ties.
Threads Similar to: any hints on how to get the springs compressed to fit back
What makes that cool compressed air noise? AggieStang General Tech 6 October 16th, 2007 03:51 PM
Mustang Buying Hints... rdnkjdi Classic Mustangs 12 March 29th, 2007 12:36 AM
Questions about Axle back & Cat back exhaust Scion V6 Mustangs 2 October 9th, 2006 07:44 AM
Are v8 front springs noticeably different vs. 4 cyl. springs 90hatch 5.0 Mustangs 3 August 8th, 2006 06:23 PM
