High mileage oil question
Old May 7th, 2006, 05:00 PM   #1
Bill is on a distinguished road
Does it really help a little with motors that are high mileage???
What exactly does it do for the motors. cause i saw quaker state motor oil that are for cars with 75,000+ miles on them.
does it work or is it just hype???
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Old May 7th, 2006, 05:10 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I think its just a gimick. My Suburban has 128,000 on it and runs like a champ. I use plain old 10w30 oil. What is it going to help? Just because a vehicle has a specific amount of miles on it doesn't mean it needs a specific oil or anything else. Mileage has nothing to do with engine wear. Abuse, weather and terrain conditions and maintenence schedule are the biggest factors. We have Suburbans at work with over 400,000 miles on the clock and they don't burn a drop of oil or make a single noise.
Old May 7th, 2006, 06:00 PM   #3
i just saw their web site and this is what it says
i just thought maybe it couldnt hurt cause i need to do an oil change soon anyway.
Motor Oil for Engines Over 75,000 Miles
Quaker State® Higher Mileage Engine™
As your engine ages, its lubricant needs may change.
Quaker State's® Higher Mileage Engine™ motor oil is specifically formulated for engines with over 75,000 miles. A unique blend of base oils, additives and a special seal-conditioning agent, Quaker State® Higher Mileage Engine™ can help:
• Restore engine performance and power
• Prevent engine leaks and oil consumption
• Protect worn engine parts
• Reduce oil consumption through evaporation and leaking engine seals
• Increase cylinder compression
• Resist oil related spark plug fouling
• Resist intake valve deposits
• Protect engine parts found in high mileage engines from wear and harmful deposits
Quaker State® Higher Mileage Engine™ can be used in all applications that specify the use of API SL, SJ, SH or SG quality oils. It meets all the performance requirements outlined by API for these service levels. Always follow manufacturer's guidelines for oil change intervals and check your oil level frequently.
Old May 7th, 2006, 07:14 PM   #4
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
I just use synthetic and seafoam
Old May 19th, 2006, 10:19 PM   #5
hrsepwr44 is on a distinguished road
if the oil was that good for old cars they would sell it for new ones too
Old May 19th, 2006, 10:35 PM   #6
stang fanatic's Avatar
stang fanatic is on a distinguished road
It's all about companies finding new and different ways to sell their product....
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old May 21st, 2006, 01:26 PM   #7
Sa-WaitNoMustang900Turbo is on a distinguished road
that oil is for cars who's piston rings are losing integrity, so unless your car is burning oil dont use that use castrol GTX for nonsynthetic it is the best, its what i use for all of my high milage cars, one thing you could do to help the car is start changing it more often though, i change mine in my oil cooled turbo car every 2000 miles for daily driving and did i mention it has the original turbo (243000 miles) in near perfect condition with no rebuild?
God... That Euro import guy is really starting to get on my nerves... my car can only beat his in a strait line(maybe)
Threads Similar to: High mileage oil question
High Mileage stanginit 99-04 3 August 14th, 2007 11:54 AM
Pump Gas Question for High Mileage Motor OcOnnor220 99-04 3 May 12th, 2007 07:21 PM
high-mileage supercharger? laserstang2 General Tech 8 February 15th, 2007 09:47 AM
power adder on a high mileage 4.6 vichael1 99-04 8 October 8th, 2006 06:42 AM
Help! (High Mileage Question) black94gt 96-98 4 September 17th, 2006 04:46 PM
