engine swaps
Old May 16th, 2006, 09:03 AM   #1
stang fanatic's Avatar
stang fanatic is on a distinguished road
engine swaps
Ok, I've seen a 350 in a stang, but does anyone know of the sucess with a 454 and where i can find all the necessary conversion goodies????
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old May 16th, 2006, 06:23 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: engine swaps
Piece of cake swap. I have contemplated it many times. I was real close to putting a 540 and a powerglide in my last car but had a change of heart. Lemons makes headers and AJE makes a k-member and trans mount.
Old May 16th, 2006, 08:55 PM   #3
kewl....but if i really do it, i want to keep the t5 or drop a t56.
Old May 16th, 2006, 09:02 PM   #4
don't think a t5 will last long behind a bigblock, even w/ aftermarket guts
88 Mustang Coupe
www.rickscarcare.net
Old May 16th, 2006, 10:17 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That will never happen. If you want to use one of those junk bucket transmissions you better stick with a 302.
Old May 16th, 2006, 11:39 PM   #6
I hear ya...can reconvert the TH400 in that case...more specific to the web site lemons
Old May 16th, 2006, 11:48 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
http://www.lemonsheaders.com/
Old May 16th, 2006, 11:55 PM   #8
ill ck em out...
Old May 25th, 2006, 09:51 PM   #9
Look Ma! My First Post!
Striklyford is on a distinguished road
My son and I are restoring an 86 5.0 GT...would a 351 Cleveland Fit?
Old May 25th, 2006, 11:11 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes.
Old May 25th, 2006, 11:36 PM   #11
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
It actually fits quite well with factory 302 mounts it will set the transmission right in the hole. the biggest expense you will come into on that swap is headers and an oil pan.
Old May 31st, 2006, 12:34 AM   #12
GTXRacing is on a distinguished road
Although I see it the 351 will fit right in place, but I also heard the T5 tranny will not work, is that true? if not is it as simple as putting the engine in, putting the t5 tranny back in place, wire it up and do your timing thing with the MSD and drive on?
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Old May 31st, 2006, 12:50 AM   #13
contact Bob at D&D. He can answer all your q's on this swap. Heck of a nice guy.
http://www.mspmall.com/ddautospec/index.html
88 Mustang Coupe
Old May 31st, 2006, 02:31 AM   #14
Yes the T5 will bolt up to the Cleveland. You need a Cleveland flywheel though. You can yank a 5.0 and bolt the Cleveland right in its place considering the motor is complete. None of the motor components exchange between the Cleveland and 5.0 other than the motor mounts. You will need to buy swap headers and everything you need to make the motor run then drop it in. It took me about 3 weeks of 2-3 hours a night after work to do mine.
*EDIT* You need an oil pan to fith the Cleveland over the fox body crossmember.
Old May 31st, 2006, 02:39 AM   #15
Wow, does it really take 3 weeks to put in an engine if you have everything you need?
GTX Racing
Tony P.
214-257-3635
Old June 1st, 2006, 12:03 AM   #16
ok...how rough is it financially and all together to cram a 460 and c-6 combo in an '87????
Threads Similar to: engine swaps
ecu swaps poisonstallion95gt 94-95 8 October 17th, 2007 01:07 AM
transmission swaps poisonstallion95gt 94-95 2 October 8th, 2007 01:20 AM
Who's got Big Balls when if comes to PI Swaps G.T. Rags 96-98 80 September 18th, 2007 11:22 AM
Engine Swaps RoushRacing99 99-04 6 July 19th, 2007 10:58 AM
Suggest a seperate post for engine swaps and brakes OTreborO Feedback Forum 3 May 30th, 2006 06:24 PM
