Shaved hatch + dead battery in trunk help!
Old April 18th, 2011, 01:31 PM   #1
foxforafriend is on a distinguished road
So I let my 1989 gt sit for 2 weeks and I tried to start it yesterday and I had no luck! The battery is completely dead and my battery is in the trunk, So I can't open the trunk Via the hatch release button, nor do I have any way of opening the hatch mechanically!
Any ideas on a way to open my hatch?
I had one idea, I have a large positive wire coming from the hatch to the engine bay. Could I give the car power by attatching a positive wire to the positive wire in the car and the negative to the frame?
or
I was reading somewhere else that I could hook up power from my other car into the cigarette lighter?
Old April 18th, 2011, 01:35 PM   #2
Absens haeres non erit
Alexander III's Avatar
'11 Performance Package
4.61@356.68
Alexander III will become famous soon enoughAlexander III will become famous soon enough
Complete fox noob, but can you take out the back seats?
Current:
'12 VW CC Sport 6MT | '10 Jetta TDI | '08 350Z Vert | '95 S14 | '85 325e
BUY MY SCT X3 UNLOCKED USED TWICE
Old April 18th, 2011, 02:23 PM   #3
I can lift them up but I have a sheet metal enclosure that won't let me get access to the battery. Unless i cut in an access which is my last resort.
Old April 18th, 2011, 02:26 PM   #4
4.61@356.68
Gotcha. Then I am out of answers. I wouldn't try doing a ghetto jump, simply because I would be afraid to short or blow something. Metal can be re-tacked/ welded.
Current:
Old April 18th, 2011, 02:39 PM   #5
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
sikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to behold
I saw this happen to a Porsche once, and they plugged a trickle charger up to something in the fuse panel, let it sit for a bit, then the trunk release worked.
MM Cobra Club #66
Old April 18th, 2011, 02:41 PM   #6
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
try jumping it?
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old April 18th, 2011, 02:47 PM   #7
mxnate116's Avatar
SVTfocus, F250
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
jump it or put a charger on it. positive on the starter solenoid, negative on the shock tower bolt.
done
and a decent charger should give enough juice to run the lock solenoid pretty quick
Old April 19th, 2011, 03:42 PM   #8
What do you guys think about my idea of connecting a car battery to a car ac adapter and plugging it into the cigarette lighter? Basically I would clamp the charged battery to the 2 wires and i would solder in a ac adapter plug. Safe for the car? I have seen people jump cars in a similar way where they plug in a cord with 2 double ended ac adapters to each car.
Old April 19th, 2011, 03:55 PM   #9
mxnate116's Avatar
SVTfocus, F250
just jump it on the starter solenoid. i wouldnt plug it into the cig lighter, you will probably pop the fuse pretty fast.
Threads Similar to: Shaved hatch + dead battery in trunk help!
Battery Dead AGAIN! Pastor J 2005 - 2010 57 March 18th, 2011 04:08 PM
Dead Battery..........Again HoustonJames 99-04 18 December 17th, 2010 10:48 AM
Dead Battery MamaStang 2005 - 2010 64 August 10th, 2010 12:34 AM
Shaved My Trunk...(Alot Of Pics) 330CubeGt Visual 26 July 13th, 2009 10:27 AM
Dead Battery Mustangshar 2005 - 2010 11 April 5th, 2009 11:34 PM
