Discussing Can you make 500+ HP with a 8.5:1 compression ratio? in the General Tech Forum. I am not sure how compression ratios work but I know that low octane fuel ...
Old May 3rd, 2007, 01:17 AM   #1
1965 Mustang Fastback
I am not sure how compression ratios work but I know that low octane fuel is a lot cheaper than premium
I am going to be building an engine in the coming months and was wondering if you could build a high horsepower engine running on low octane gas?
Is this going to be hard? I am talking just engine here not s/c, etc.
and Ive been told 9.0:1 will still require 93 octane gas??? Is this true?
Old May 3rd, 2007, 02:12 AM   #2
what will be the engine displacment?
Old May 3rd, 2007, 02:19 AM   #3
351 windsor stroked to 393 using a chp kit
Old May 3rd, 2007, 04:16 AM   #4
i dont see it happen on 87 oct.
Old May 4th, 2007, 05:07 PM   #5
TurboLX's Avatar
not at all, you will have some SERIOUS detonation
Old May 4th, 2007, 05:07 PM   #6
TurboLX's Avatar
which is bad and causes piston slap
Old May 4th, 2007, 05:27 PM   #7
or a collapsed ring land
Old May 4th, 2007, 07:59 PM   #8
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Naturally aspirated and 393 cubic inches, possible but not cheap. More cubes or a blower would help. 9:1 will run fine on 87 octane. Detonation doesn't cause piston slap. Excessive piston to wall clearance does.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old May 5th, 2007, 08:21 AM   #9
i think running 87 oct. with 393 cubes you will have to cut back the timing and wont reach the 500 mark.
Old May 5th, 2007, 10:28 PM   #10
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Cubic inches has nothing at all to do with octane required. Compression, timing, power adders, cylinder head material and sometimes cam overlap do.
Old May 5th, 2007, 11:35 PM   #11
im not claiming that cubes has anything to do with octane requirements. im stating that with 373 cubes, and enough compression to make the 500 mark, you would have to dial back the timing to keep from detonating which would make him shy of 500. now on 93 octane it might resist knock enough to reach 500.
Old May 6th, 2007, 05:22 AM   #12
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
You can make 500 hp with a 393 and 9:1 compression and 87-89 octane.
Threads Similar to: Can you make 500+ HP with a 8.5:1 compression ratio?
Compression Ratio itschristorres8 Engine 22 December 1st, 2007 01:46 PM
Compression Ratio scxc15 Modular Mustangs 4 September 24th, 2007 11:01 PM
compression ratio mustangrebuilder Classic Mustangs 13 August 14th, 2007 10:08 PM
compression ratio for 93' 5.0 V8 w/ modifications kelbry Engine 4 May 10th, 2007 10:37 PM
96 gt compression ratio 96_gt_stanger 96-98 3 March 2nd, 2007 11:52 PM
