Ball Joints
Old April 27th, 2011, 10:30 AM   #1
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 15 reviews
Ball Joints
I noticed when changing my front springs that the rubber surrounding by Ball Joints was busted. You could move your finger across it and get grease. Should I look into replace them?
I plan to get the Steeda X2 Balljoints, but can't afford them right now, so I would just buy standard ones.
How hard are they to replace?
Black Bullitt Rims FT/FS
Looking to Sell or Trade for Silver FR500s
Looking to buy a lot of 99-04 Interior Pieces
If you have any for sale, PM me
Old April 27th, 2011, 10:38 AM   #2
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
Yes, replace them. If the rubber is busted, it's only a matter of time before they dry up and get a bunch of crap in them.
They shouldn't be difficult to replace. Just borrow a ball joint press from your local auto parts store. Also buy a ball joint seperator (also called a pickle fork) if you don't have one.
Old April 27th, 2011, 10:47 AM   #3
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
i woould buy the nice ones that i think Steeda sells, they are made for lowerd mustangs
sorry i remeber the name of them lol
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old April 27th, 2011, 10:11 PM   #4
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Steeda X2 Balljoints. I meantioned them in the first post, but I can't afford them right now. I will probally go ahead and replace them... whats $40 and a day of work?
Old May 1st, 2011, 03:10 PM   #5
1997 F-250, 1978 F-150
est14.6@96
FordmanT is on a distinguished road
$40? for one maybe. I never do one, for the amount of work it's worth it to do all of them. Or if your wanting the Steeda ones then don't bother for now, there is still grease in/on them they are fine for a while still, not good but not gonna leave ya anywhere anytime soon. Is there play in them yet? Also you don't need a pickle fork or really want to use one cause they can do a lot of collateral damage. Just hit the area where the taper of the ball-joint stem sits in the spindle or arm sharply with a dead-blow ball-peen or mini sledge, from the side. Hit it as flat as you can, hammer face to surface, and it'll just drop out after a couple good whacks.
4SALE:misc 04 cobra: SVT 4vHeads port/polish/deck @SVT, CenterForce dual friction clutch, 4lb crankpulley, Steeda Foxbody strut tower brace, Accufab Intake tube PM 4 info
Old May 3rd, 2011, 10:11 AM   #6
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
$21 each at Autozone.
When you mention play, what kinda of play would I be looking for?
Old May 3rd, 2011, 05:52 PM   #7
est14.6@96
Wow, that is super cheap! If you grab the top of the tire with one hand and the bottom with the other, with the tire off the ground, and try to rock it (pull with one arm push with the other, alternating quickly). You'll have to apply a good deal of force but if you can feel any play at all then have someone help you to watch where it is coming from, worn out wheel bearing will do this to. A good trick to feel if its the joint is to have one person rock it and another push their finger fairly hard into the space between the two parts, where the rubber boot is, and if they can feel the two pieces move separately then there is play. If they are really worn out you'll feel and see the play without anyone's help. If it's the bearing then it will also have play from side to side (grabbing the tire on the sides and rocking back and forth). If there is only side to side play but non up and down then you have worn steering joints (tie rods).
Old May 3rd, 2011, 08:07 PM   #8
00redgt's Avatar
2000 mustang gt
00redgt is a jewel in the rough00redgt is a jewel in the rough00redgt is a jewel in the rough
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
i just used a big hammer for mine
Old May 5th, 2011, 09:31 PM   #9
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
The car is at the shop atm getting a tire put on, balancing, and alignment. Gonna get them to check the balljoints while they are in there.
Old May 6th, 2011, 11:33 AM   #10
est14.6@96
Good call, any good alignment shop should do it without your asking, if you think they are full of it then try out the way I told ya.
Old May 6th, 2011, 11:25 PM   #11
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Well, the guy that does alignments left at 3pm because his wife went into labor... cant complain about that Lol.
Old May 10th, 2011, 12:18 AM   #12
est14.6@96
Haha, wouldn't do any good any how!
Old May 10th, 2011, 09:41 AM   #13
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
What wouldn't do any good? Regardless if I need ball joints or not, I need an alignment since I changed the front springs. My tires are bending inward at the top atm.
Old May 11th, 2011, 11:32 PM   #14
est14.6@96
I meant wouldn't do any good to complain about him not being at work. You know, you could complain but it won't do any good any how. Not about you getting a necessary job done, the alignment.
Old May 12th, 2011, 09:15 PM   #15
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Ahh, gotcha.
Threads Similar to: Ball Joints
X2 Ball Joints 4.6DreameR 99-04 12 March 1st, 2011 09:11 AM
Steeda X2 Ball Joints look really similar to Foxbody Ball Joints... asiansensation78 99-04 3 December 26th, 2010 08:33 AM
X2 ball joints? 01KnightRiderGT 99-04 2 March 4th, 2010 07:09 AM
Ball joints hardhitter 99-04 3 April 4th, 2009 03:45 PM
Ball joints? dmachine22 99-04 19 May 3rd, 2007 08:07 AM
