Fuel filter line
Ok, I looked in front of the gas tank and noticed the fuel filter on my 1987 looked original. I also noticed that there was a line beside that one. Is that also some type of gas hose? It was in the process of being melted by the exhaust pipe !!
1986 Mustang LX
![]() iTrader: 1 reviews
That one sounds to be the fuel return line and from the sounds of it needs to be replaced soon. Otherwise, you might find yourself in an "explosive" situation.
Is the hose just regular 3/8 " fuel line hose or something special.
it's a special plastic line, you might have a hard time getting a section of 3/8 rubber line to seal if youre looking to just repair the section
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
I see....plastic. I guess I will get the OEM replacement. I need to figure out something so it will not happen again. currently have the lines out of the way held by a few ties.
Is it pretty easy to repair?
I was just thinking back......My rodeo uses a rubber fuel hose and my 96 cobra used a rubber fuel line too. Do you think I can just go back and replace it with a rubber fuel line? I am not talking about the steel lines just the ones that connect to the feul filter. Has anyone else done this ? Thanks
itd be easy to just replace it with the correct line....dont create another issue for yourself down the road much less on the road
I guess I am afraid of the plastic line melting again. The rubber fuel line would not have melted. I will go back with the OEM hose but do a rubber insulation around it just in case the ties break again and the line ends up laying back on the tail pipe.
I wonder where can I buy this special plastic line? Ford told me it is discontinued.
ck out : www.cjponyparts.com
www.texasmustang.com
Threads Similar to: Fuel filter line
| Lucas fuel injector cleaner and fuel filter | Saleen0101 | Modular Mustangs | 0 | September 25th, 2007 04:09 PM |
| Fuel line | jbm5781 | 96-98 | 18 | August 15th, 2007 12:02 AM |
| Fuel Filter | 06RedfireGT | The Clubhouse | 12 | August 13th, 2007 02:29 AM |
| fuel filter | flattusmaximus78 | V6 Mustangs | 37 | July 28th, 2007 12:02 PM |
| fuel filter | JASonic | V6 Mustangs | 2 | February 25th, 2007 12:30 PM |
