Insrument Panal removel
Old May 21st, 2006, 10:01 PM   #1
cobralini is on a distinguished road
I need to replace some dash bulbs. How do I remove it on my 87 GT ?
Old May 21st, 2006, 10:16 PM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
removed upper and lower column covers, two bolts hold the plastic cover assy, and on the right side you'll see a metal bar, youll need to remove the screw securing it, 2 screws on top (one can come out with stubby, and the other with those s shaped screwdrivers). pull the housing out enough to reach behind and disconnect the flasher, defrost, hdlamps, and fog lamps connectors. pull plastic housing out, 4 screws hold dash assy in, remove, pull assy out and disconnect the two harness and speedo cable and its out! reverse order to install but NOTE: when re-installing swith connectors on outer plastic assy, fords connectors are known to not hold the wires in so make sure the wires dont push out when reconnecting or else flashers and turn signals wont work...
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old May 22nd, 2006, 09:58 AM   #3
THANKS!! you may have just solved my turn signal problem !!!
Threads Similar to: Insrument Panal removel
radio removel help Blackbeauty v601 Audio/Video 19 September 18th, 2007 06:09 PM
bumber removel knightster420 V6 Mustangs 10 August 23rd, 2007 01:16 AM
Manifold Removel Help... In Progress Pro Form 2005 - 2010 1 September 29th, 2006 10:47 PM
