Volts
Old May 21st, 2006, 11:05 PM   #1
cobralini is on a distinguished road
Volts
The car runs and starts fine but when I turn on the A/C the volts drop real low, it happens when I turn on the lights too. This is at idle when I noticed it.
Old May 21st, 2006, 11:10 PM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
is your idle staying where its supposed to be??? if so, alt goin bad because its no longer pumoing out enough amps to keep up with the loads.
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old May 21st, 2006, 11:13 PM   #3
MSTNGRCR13's Avatar
1986 Mustang LX
MSTNGRCR13 is on a distinguished road
If the battery is old, then it might be one of the problems. However, if you have a voltage regulator going bad, this could also be the problem. You can take the car to your local Autozone and have it tested right there to get a better idea because everything electrical runs off the battery after the car is started and V/R might not be putting out enough voltage to power all the accesories while at idle. I would have to say that a good fix would be to change out the alternator as the V/R is built into it.
Old May 21st, 2006, 11:21 PM   #4
all so true, but the regulators are internal and if its failing, then a new unit is a better investment...lack of voltage is due to low voltage from the battery. its amperage that matters....i can produce 14 volts, and run a car all day with just so many amps, but as soon as i load the sytem with an amperage draw...it starts to draw the voltage down because the draw is higher than the output...
Old May 24th, 2006, 12:00 AM   #5
173speed is on a distinguished road
If you have underdrive pullies..u may come across having this problem..from wat i understand with the underdrive pullies that i have the car doesnt really charge well below 2000 rpms....i have this problem during the winter since all i do is warm up the car...
SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$%
Threads Similar to: Volts
volts gauge????? marks87gt General Tech 2 July 13th, 2007 08:26 PM
Fuel Pump getting 5 volts OTreborO 5.0 Mustangs 69 March 11th, 2007 11:35 PM
WTF? (5 Volts Through Entire Harness) 88Horseman 5.0 Mustangs 0 October 22nd, 2006 11:33 PM
