Can a water pump lock up?
Old May 12th, 2007, 12:47 AM   #1
monkey187 is on a distinguished road
I was driving my car today and my water pump locked up and melted my serpentine belt. My gatorback had no chance, baught a cheap one and it was working fine then my water pump locked up again. Had to tow my car for $50 to go 3 blocks. has this happened to anyone else or what the f*ck is wrong with my car?
Old May 12th, 2007, 01:13 PM   #2
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Breakout is a jewel in the roughBreakout is a jewel in the roughBreakout is a jewel in the rough
Send a message via AIM to Breakout
I'm not sure if water pumps can actually "lock up", but they can and do sometimes go bad. If it went bad, that would cause your engine to overheat. Was your car overheating before the belt melted/borke?
Old May 13th, 2007, 02:02 PM   #3
stang fanatic's Avatar
stang fanatic is on a distinguished road
If your water pump is truly 'Locking up" then theres something wrong with either the pump or your running straight water. the pumps use the coolant for lubricity so if your running a reman pump, chances are somethings wrong witht the bearings theyre using
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old May 13th, 2007, 08:20 PM   #4
I will be taking it off and checking what really went wrong with it this week. I am hoping that there isnt more damage.
Old June 17th, 2007, 10:43 PM   #5
crazytaz's Avatar
crazytaz is on a distinguished road
if your pulley on the water pump doesn't move. than your pump is locked up. your alternater or a/c compressor can also lock up. check all your pulleys to make sure they all move freely
Threads Similar to: Can a water pump lock up?
Bad Water Pump? gotboost562 5.0 Mustangs 18 April 4th, 2012 06:31 PM
what water pump 95wip 5.0 Mustangs 2 June 25th, 2007 12:04 AM
Can a water pump lock up? monkey187 99-04 7 May 14th, 2007 07:31 AM
Water pump ??? Fastback GT Classic Mustangs 15 February 24th, 2007 02:37 PM
Water Pump cobralini V6 Mustangs 1 August 3rd, 2006 06:48 PM
