starting problems
Old June 22nd, 2011, 09:51 PM   #1
snakeandshake is on a distinguished road
starting problems
Good evening, I went to start up my car tonight for the first time in a year or so and the starter wouldn't stop cranking. I turned off the ignition and it still was cranking. I pulled out the key and it's still cranking! I yelled for my son to pull the battery cable, it's the only way it would stop cranking. My question is: Would it be the starter relay on the firewall, or maybe the starter itself? Any help would be appreciated.
Old July 1st, 2011, 11:11 AM   #2
wizwrath is on a distinguished road
Not sure what kind of car you have, we would check/change out the ignition switch first, then change the solonoid, I doubt it could be the starter itself since the it needs the voltage to keep operating.
Old July 1st, 2011, 08:07 PM   #3
thanks for the advice. The car is actually a 1970 Torino Cobra SCJ, with c-6, and it's the first time I've ever run across this problem. Thanks!
1970 Ford Torino Cobra 429SCJ
2007 Jeep Grand Cherokee SRT8 6.1 Hemi
Threads Similar to: starting problems
starting problems mustangmatt123 94-95 1 October 4th, 2010 01:09 PM
starting problems Danderson 5.0 Mustangs 6 June 23rd, 2010 02:51 PM
Starting Problems 82DragMan 5.0 Mustangs 5 April 29th, 2007 06:46 PM
Starting problems Mudv216 5.0 Mustangs 5 April 16th, 2007 01:03 AM
Problems Starting Donbeil 96-98 0 January 11th, 2007 09:12 PM
