Discussing my window dont work in the General Tech Forum. the window on my mustangs dont go up right...it goes off to the side..... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2001 Camaro z28
my window dont work |
1999 Ford Mustang V6
14.79 @ 92.15
What year is it? Is it power or manual? You can remove the door panel in 1 minute on most Mustangs. I don't know what the problem is, but you should be able to fix it yourself because the window pullies and motor are pretty simple to work with.
2001 Camaro z28
its a 2001 mustang gt and the windows are power and i have been thinking of just removing the door panel myself[/quote]
good question i could look into it, and get back to ya
2000 V6 Performance Red @ Cardomain NO LONGER :*( 1987 LX Hatch | Soon to be a 600hp monster |
sounds like the window run channel is broken. Remove the door panel and look at the channel the window rides in. The channel clips into the door frame and has a bracket on the bottom w/ 1 bolt holding it into place. My guess is that the bracket broke where it's welded to the channel. Have it rewelded or just buy another channel.
88 Mustang Coupe 2006 FFW Richmond True Street Runner-Up www.rickscarcare.net http://img146.imageshack.us/img146/2158/ricksadql2.jpg |
14.79 @ 92.15
if it goes off to the front or rear, then either the front or rear lower clip could be loose or broken. if it goes off to the left/right, then 1/2 of the clip could have broken off of either the inner/outer halves of the clips
Threads Similar to: my window dont work
| HEY!! VERY SAFE FOR WORK... dont worry | Onemanzu | The Clubhouse | 9 | October 4th, 2007 01:41 AM |
| i just dont get it.. | TurboLX | The Clubhouse | 208 | June 15th, 2007 05:42 AM |
| dont know what to do | 9stang1 | 5.0 Mustangs | 1 | January 16th, 2007 07:54 PM |
| dont no wat it is | Rolis | V6 Mustangs | 21 | December 28th, 2006 10:06 PM |
| 1000watt amp and 1000 watt sub..dont work | itschristorres8 | Electronics | 19 | December 3rd, 2006 10:19 PM |
