Engine wont start. . . .I need help
LinkBack (1) Thread Tools
Old June 30th, 2011, 02:14 PM   1 links from elsewhere to this Post. Click to view. #1
rfcsoulja's Avatar
01 True Blue v6
to slow to matter
rfcsoulja will become famous soon enough
Alright. My 01 v6 mustang will crank and crank but won't start. . .Unless it really wants to. Here are the circumstances. I'm in the parking lot installing my wideband. I think I have everything wired up correctly and I go to start my car. It cranks and cranks but won't start. So I'm thinking "surely me messing with fuse 37 under the dash wouldn't cause this issue right"? Ok, well I go up stairs for about 30 minutes. When I go back to my car, it starts fine and I drive the the skating rink, then to a movie, and back home. Total of about 30 miles of driving. I wake up the next morning, it starts and I go to the eye doctor. When I come out, it doesn't start, just cranks. I wait for about an hour, same thing. I get it towed to my house and this morning I changed the fuel filter. It started up fine (ran a little rough for a little while). I turned it off and started it 3 more times. Come up stairs for about 40 minutes. Go back down, now it wont start again. I've done the wiring upgrade with the svt focus fuel pump all the way to the fuel pump itself. The times it had ran, its run and idles fine. Any ideas?
My supercharged v6
http://www.youtube.com/watch?v=1lNkgKBw0bw
Old July 4th, 2011, 03:32 AM   #2
Special
Drak's Avatar
2001, Ford, Mustang GT
13.73
Drak is on a distinguished road
put a pressure gauge on the fuel line to see if you are getting pressure,if so then more than likely its not your fuel system, and if its not fuel then if you have a multimeter check if you are getting voltage to the coils also you could always check the OBD2 port to see if any codes came up. and also make sure your MAF sensors wires are secure. just some steps to try to help narrow down the field
Want it back so bad!
Old July 5th, 2011, 09:20 PM   #3
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
Could be a CCRM problem.
PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/224301-engine-wont-start-i-need-help.html
Thread Engine wont start. P1260 | Forums at Modded Mustangs | BoardReader This thread Refback April 20th, 2012 06:04 PM
Threads Similar to: Engine wont start. . . .I need help
Engine Shut off while driving, Now wont start. Please help.. koessl 96-98 21 March 11th, 2010 10:35 PM
wont start help 86_gt_stang 5.0 Mustangs 0 February 18th, 2010 04:05 PM
4.2 swap, engine wont start 99v6stang V6 Mustangs 47 October 11th, 2007 07:49 PM
Engine wont start, only with ether, Please someone help bengt87 5.0 Mustangs 2 August 18th, 2007 01:01 PM
