cant figure this one out.
Old July 2nd, 2011, 07:40 PM   #1
pelley's Avatar
1993 Mustang LX
pelley is on a distinguished road
alright the car is a 1993 Lx 5.0 manual.
the car wont start by turning the key and holding the clutch in.
fuel pump primes, theres not even a click at the solenoid.
and the solenoid is new, just replaced it, cleaned the connections, have to touch the starter solenoid bolts together to get it to run.. and when i do that i dont have to press the clutch to start it that way, any ideas?
no bad fuses either. stumped.
any help is appreciated.
Old July 3rd, 2011, 02:59 AM   #2
5.0ranger is on a distinguished road
is the start switch wire pushing 12 volts when you turn the key on to start? it should be a yellow wire. i think.
Old July 3rd, 2011, 03:00 AM   #3
also. is the silinoid grounded well? I had to run another ground strap off of mine to get it to ground good enough.
Old July 3rd, 2011, 02:44 PM   #4
pelley's Avatar
1993 Mustang LX
don't have a voltmeter available, but the fuse in that link looks good,
the car battery was dying because a bad ignition switch which kept the accessories on when the key was out, so i replaced the switch now everything turns off , bu the car still wont start by key, have to jump the solenoid, and i know its grounded good, i went through with a wire brushed and cleaned everything up...
Old July 3rd, 2011, 04:45 PM   #5
try to arc the wire while someone else turns the key on. if it arcs then you have 12 volts. im almost certain that's what it is.
Old July 3rd, 2011, 11:36 PM   #6
Street Jesus's Avatar
80 Mustang Cobra
Street Jesus is on a distinguished road
Spend a couple bucks on a 12v test light and see if the "start" wire going to the solenoid has power.
Old July 4th, 2011, 04:17 AM   #7
Special
Drak's Avatar
2001, Ford, Mustang GT
13.73
Drak is on a distinguished road
might be as simple as your Clutch Safety Switch.
Want it back so bad!
Old July 4th, 2011, 06:30 PM   #8
pelley's Avatar
1993 Mustang LX
gotten all the wires correctly, all receive power.. its something else..
Threads Similar to: cant figure this one out.
I'm trying to figure out which is which. Fir3controlman 99-04 0 July 10th, 2010 10:26 PM
still can't figure it out... can anyone help?? delgadog 94-95 4 June 28th, 2009 11:36 AM
cant figure it out... ZoomZoomMFer 99-04 19 May 29th, 2009 04:24 PM
cant figure out what to buy... mustangsoldier 5.0 Mustangs 29 April 13th, 2009 10:48 AM
cant figure it out ttop5.0 5.0 Mustangs 2 August 26th, 2006 06:54 PM
