Intelligent nitrous oxide....
Old May 13th, 2007, 11:43 PM   #1
homebrewed's Avatar
'88 LX body '91 GT D/T
8.7 in the 1/8th
homebrewed is on a distinguished road
I have a 1991 LX 5.0. Its a street car. Tags, insurance, inspection, all the things that make it legal... ish. 306 CID, B303 cam, 3.73's, T-5, springs, dampers, aftermarket exhaust from the block back, etc.
I will be making a few appearances at the local tracks around my area. I am going to put spray on it until I can afford to refresh/replace/S/C the engine.
I am looking real hard at a 150 shot or so. Any ya's or na's on this idea? Wet or dry? I do know the differance between the two, but is one more reliable/safer/better than the other on a 5.0? Any input is appreciated.
Thanks!! HB
Founder of the I don't like my shit centerd and want it back the way it was dammit! club
www.myspace.com/evoalliance
greatest band alive
Originally Posted by Tony_90fox View Post
I wish there was a :lickmynuts smiley, because i would use it now
:lickmynuts
Old May 17th, 2007, 04:21 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
you can use the 150 shot on your setup, the only difference between dry and wet is one makes more power, and thats dry,
Old May 17th, 2007, 04:39 PM   #3
1stimeford's Avatar
1stimeford is on a distinguished road
Just curious, but how would it make more power over wet? Nitrous oxide is nitrous oxide isn't it?And thats not true about being the only difference...Dry is injected seperately from the fuel and wet is injected with the fuel. Correct?
________________
JLT CAI, Accufab 70MM TB/Plenum,Xcal 2/BamaChips Tune
Old May 17th, 2007, 07:33 PM   #4
droppedbass87 is an unknown quantity at this point
Send a message via AIM to droppedbass87
yeah thats what i thought??
Old May 17th, 2007, 07:38 PM   #5
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Your wrong...
Wet adds fuel along with nitrous...
Dry just sprays nitrous...
Dry kits are easier to install...
Wet kits take alittle more work...
And its preference...
From what i have read from "TurboLX" on nitrous I dont really think he has any experience with it...
Facebook
Google+
Old May 18th, 2007, 01:28 AM   #6
Drgnracin72's Avatar
Your wrong...
+100
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old May 18th, 2007, 09:06 AM   #7
banned is on a distinguished road
Considering selling my car to fund my race car: take a look and tell me what you think.
http://www.moddedmustangs.com/forums...ml#post1041280
Old May 18th, 2007, 04:09 PM   #8
TurboLX's Avatar
oh shitt... i thought i put down wet, no seriously my bad, i know nitrous but not as much as others
Old May 23rd, 2007, 01:10 AM   #9
homebrewed's Avatar
8.7 in the 1/8th
Good good... Keep comin'.
Whats the negative/positive side to either on a 5.0. I have heard that nitrous tends to "pool" in the intake. Any merit to that? If so, would a dry kit be more prone to not doing this?
I have done a few wet systems in various cars and 2 dry systems. The dry were bikes.
greatest band alive
:lickmynuts
Old May 24th, 2007, 12:12 AM   #10
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
puddling is primarily caused by low bottle pressure,or too big of a fuel jet. wet kit is safer, dry is safe but is more prone to harm. by that i mean, the larger the shot the more stress to the fuel system. you will have to make sure that the fuel delivery can keep up. if the car is tuned and set up correctly it will be fine.
Old May 24th, 2007, 12:40 AM   #11
hey sweet2kstang i need a lil help..did you tap into your schrader valve with your nitrous kit...??well do you take off the stock schrader valve and get a fitting that goes in its place??because if you just screw your hose onto it with the stock schrader valve you wont have any fuel going to the solenoid..am i right??
Old May 24th, 2007, 02:35 AM   #12
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
you will have to take off the schrader valve fitting and put on a fuel rail fitting in its place.
Old May 24th, 2007, 02:26 PM   #13
ok i see..i will try lowes cuz i didnt get that fitting..hey do you have any pics and close up pics of yours??
Old May 25th, 2007, 08:44 AM   #14
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
this should be the fuel rail fitting you need. http://www.jegs.com/webapp/wcs/store...-1&showValue=1
and a couple pis of my set up:
Old May 25th, 2007, 11:31 AM   #15
yeah i ordered one but i ordered one and the end coming up is a male..not a female..
Old May 25th, 2007, 11:33 AM   #16
and mine is a 1/16 in the fuel rail not a 1/8th..and your set up is bad ass..but where is your wot micro switch that activated your window switch??
Old May 25th, 2007, 02:40 PM   #17
MeZ
MeZ's Avatar
MeZ is on a distinguished road
HB .. Basically .. running too rich or too lean leads to this. Puddling is cause by basically not allowing the fuel and nitrous to atomize properly causing pooling or puddling of fuel in the intake manifold. I know alot of people .. even myself have thought that it was just spraying under a certain rpm period that cause engine detonation.. but it really depends on what gear you're in and how fast you are going .. spraying in 1st and 2nd .. you can pretty much spray at anytime you're slamming and throwing those gears .. but spraying too early in the later gears or spraying going to slow in the later gears can cause engine detonation ... that is why you want to have control over what rpm you spray at to ensure it doesn't spray at the low rpm in a higher gear ...
And by they way .. IMO ... and in the opinion of many pros, Wet is better than dry for this reason. The "dry" system uses the factory fuel injection to enrich the nitrous introduced into the engine. What sucks is that no matter how much nitrous is delivered at a certain intake port it always gets the same preset amount of fuel, and if a fuel injector becomes clogged you're f'd. The "Wet" system introduces a precise amount of fuel and nitrous through the nozzle that atomizes the fuel to microscopic proportions. This allows every cylinder to receive a precise mixture of fuel and nitrous insuring a safe and powerful set up
Car For Sale on Autotrader.com
04 Silver GT 32K Miles
Parts 4 Sale:
18" Wheels SSR GT3 replicas w/ tires
Steeda Tri-Ax
10lb N20 Bottle w. gauge
(2) Kirkey Racing Seats w/ RCI 5 Pt. belts
Steeda & Momo shift knobs
SB GT Spoiler
Old May 25th, 2007, 08:12 PM   #18
well lets im going to run 3 times only at the track and all i have is the micro wot that comes with the kit and then goes to the relay to activate the system..is thqat ok for only 3 runs guys??cuz after that im ordering the rpm progressor..
Old May 29th, 2007, 11:18 PM   #19
homebrewed's Avatar
8.7 in the 1/8th
Thanks for the "wetter is better" advice....
So I'm lookin' at the fuel system...
Holley 190LPH in-tank pump, Aeromotive or Holley adjs. regulator and 24lbhr injectors. Are larger injectors necessary for the 150 I have my sights set on? Also, larger rails? Yes no?
Nice set-up SWEET2KSTANG :award Looks good
greatest band alive
:lickmynuts
Old May 31st, 2007, 04:53 PM   #20
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
thank you. larger injectors, pressure regulator, or fuel rails arent nesseccary to upgrade on a wet nitrous set up. maybe on a dry but that will be something that you will need to talk to your tuner about. i am running a 125 shot on my car with just the mods that are listed in my garage. a fuel pump or boost a pump is recommended after 100, but is up to you wether you want one for anything less.
Threads Similar to: Intelligent nitrous oxide....
nitrous oxide gtdan 96-98 5 October 14th, 2007 12:58 AM
Intelligent Design VS Total Chaos BoostedMKIV The Clubhouse 106 April 29th, 2007 01:36 AM
Nitrous Oxide help TDog 2005 - 2010 11 April 12th, 2007 08:53 PM
Nitrous oxide questions Barrier Modular Mustangs 4 January 29th, 2007 12:24 PM
