88 grand marquis 5.0 bucking bad at light acceleration 55mph
Old July 6th, 2011, 05:20 PM   #1
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
So I replaced, Plugs, Wires, Cap, Rotor. Still bucked. Replaced Module. still bucks. It happens when Im in 4th gear in a AOD and slightly step on gas. Will also happen when I reach 70 mph. If I WOT from start to 70, no problem. Could this be a fuel problem?
Old July 6th, 2011, 11:39 PM   #2
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
When is the last time you changed your fuel filter or used a fuel injector cleaner? Also I would check your TPS sensor.
PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune.
Old July 7th, 2011, 09:10 PM   #3
Ohsplat's Avatar
1983GT
No motor or trans
Just changed fuel filter today. Never used injector cleaner. TPS sits at .9 volts and idle. Slowly raises to 4.35 at WOT. Fuel pressure sits a 32#, and stays at 32 when revving. You can hear popping in the exhaust but its not a backfire. Coil tested .9 on the primary coil and 9k on the secondary... all within specs... im lost.
Old July 7th, 2011, 09:14 PM   #4
Ohsplat's Avatar
1983GT
No motor or trans
The bucking is real bad. Feels like im running out of gas...To make sure a injector is working, cant you hook a lead up to the pos bat term and touch it to the pos on the injector to listen for the click.
Old July 8th, 2011, 01:47 AM   #5
1997 Mustang GT
Just checking the voltage of the TPS doesnt usually work. Ud need to use a scan tool to see a graph. They normally only go bad at a certain rpm and are fine everywhere else, so they can be tricky to find. Also if you want to check for injector function you would need a noid light. One injector going bad wouldnt really make it buck horribly tho. Just a misfire. Have any CEL codes?
Old July 8th, 2011, 01:56 PM   #6
Ohsplat's Avatar
1983GT
No motor or trans
engine off codes.
11
12
engine on codes.
12
33
45
74
I do know the egr vacuum is unhooked and blocked off because it broke, but that was after this all started.
Old July 8th, 2011, 03:27 PM   #7
Ohsplat's Avatar
1983GT
No motor or trans
Fuel pump is bad. Used a set of snap on gauges instead of autozone rentals and it showed 28# at idle. When i floored it with the snap ons hooked up, it dropped like a brick.
What have I learned from this.. the mechanic is only as good as his tools lol.. dont buy cheap shit.
Threads Similar to: 88 grand marquis 5.0 bucking bad at light acceleration 55mph
Grand Marquis performance Mustang Boy All Other Vehicles 0 November 8th, 2010 07:41 PM
Piston from a grand marquis Steve03GT 99-04 6 September 14th, 2010 11:16 PM
PI swapped Grand Marquis? JerseyTrueBlue 99-04 4 June 21st, 2010 06:40 PM
Anybody have some experience with 5.0 CV/Grand Marquis? Monark The Clubhouse 2 September 9th, 2009 10:32 AM
