What can switches be used for?
Old July 25th, 2011, 01:59 AM   #1
2005 Mustang V6
Huntdog111 is on a distinguished road
I have 3 switches on my center console, and am wondering, what they can be hooked up to? It would be neat to use them. Thanks.
Old July 25th, 2011, 02:15 AM   #2
Dancing Naked In The Rain
mcqueen's Avatar
You could pretty much hook them up to anything electronic that you can dream up. All you need is some basic wiring skills and I can assure you that it's really not hard to wire stuff if you keep your dreams pretty simple I personally put a switch on my center console for lights in the footwells
My Hubpages
Hey.. r u really a tranny??
Old July 25th, 2011, 02:26 AM   #3
Blown284's Avatar
1966 Mustang Coupe
Won't See The Track
Blown284 is a jewel in the roughBlown284 is a jewel in the roughBlown284 is a jewel in the rough
Send a message via Yahoo to Blown284
+1
Anything electronic. I.E. Fuel pump, electric fans, power to stereo, ignition kill switch the list goes on...I say get nitrous and use one of the for that
Previous Rides
1997 Blown Cobra-Sold & Missed
2004 Lightning-Traded
2001 Turbo GT-Traded
1966 Mustang Coupe-Sold
2006 Audi A3-sold
1998 Bagged Silverado- Sold
1997 BMW AC Schnitzer 540i S5
Old July 25th, 2011, 02:43 AM   #4
mcqueen's Avatar
^ I like the way this man thinks
My Hubpages
Old July 25th, 2011, 04:11 AM   #5
2005 Mustang V6
Would I need to remove the console? Or just splice some wires? Say I want to add some led's, would I hook the lights to the button then the fusebox?
Old July 25th, 2011, 04:15 AM   #6
mcqueen's Avatar
I'm not familiar with S197 interiors so I'm not sure if you have pieces that can pop off and get you access to the rear of the switches. Are the switches currently hooked up to anything? For some LEDs I would tap a power source and a good ground then run them to one of the switches. Then run the wiring from the lights to the switch. I would skip the fuse box and simply run in-line fuses (although I didn't use any in-line fuses, it is safer to use them).
My Hubpages
Old July 25th, 2011, 04:49 AM   #7
2005 Mustang V6
Not connected to anything that I know of. I guess the only way to find out is to pop the panels out. What power sources could I tap into? How would I do that? I don't have any experience with automotive wiring. Thanks
Old July 25th, 2011, 01:26 PM   #8
mcqueen's Avatar
My favorite power source is the cigar lighter/accessory port. It's really as simple as cutting a small piece of the plastic casing off of the power and ground wires and attaching new pieces of wires to them (in a T shape so that your cigar lighter still works, it just allow power to your switch). Then use some electrical tape to ensure the wires aren't exposed. I like the cigar lighter/accessory port wires because they get power even when the car is turned off so you can turn your lights on if you just run out to your car at night and need to find something on the floor.
I also highly recommend picking up a Hayne's manual for your car. They have all the wiring diagrams in the back of the book so you can just look over them and figure out which wires are power and which are ground (they generally tell the wire colors).
My Hubpages
Old July 25th, 2011, 01:37 PM   #9
2005 Mustang V6
Thanks, ill have to try that sometime soon. The manual sounds like a good idea.
Old July 25th, 2011, 01:42 PM   #10
mcqueen's Avatar
It's a life saver man, you can't imagine how many times I've consulted that thing when I get stuck on something
My Hubpages
Old July 25th, 2011, 02:27 PM   #11
2005 Mustang V6
Haha, sorry your having to use it right now. I just read your engine project thread, that sucks. Good luck and thanks for all the help.
Old July 30th, 2011, 12:53 PM   #12
invsn is on a distinguished road
hook them up to anything electronic, can literally be used for anything and everything haha
Threads Similar to: What can switches be used for?
LED Lighting Switches TheDragon V6 Mustangs 22 December 13th, 2010 12:38 AM
What are these switches??? atlckb V6 Mustangs 18 August 13th, 2010 09:22 PM
Window switches 01V8MUSTANG Audio/Video 6 December 3rd, 2009 07:13 AM
Switches WeCircleTheProblem Audio/Video 14 July 28th, 2006 02:28 PM
