2003 Ford Mach
Traveling at the speed of a photon
California Emission laws...
What can be dont to an exhaust to pass a smog test out here in California? i have weld in flowmaster mufflers.btw any of you know if the new 44's are better than the 40s flows?
http://www.racingbeat.com/emissions.htm
Can I legally replace an emissions sensitive part on my car with an aftermarket product? In the state of California, it is not legal to replace an emissions sensitive device without the replacement part having an exemption from CARB. Although replacing a particular device might have no apparent effect on the emissions, and the car might even pass a tail pipe "smog-check", the replacement part is still not considered emissions legal. In many cases, the mandatory visual inspection of the vehicle prior to an official state required smog-check may result in immediate failure of the test if a non-exempt part is identified. A part that has been issued a CARB exemption has been subjected to strict laboratory testing as required by CARB in order to demonstrate that the replacement part will not increase emissions. (These tests are NOT the same as the "smog check" test and often require "cold start" testing procedures in order to test the efficiency of the emissions system during the initial seconds of the start-up cycle.) A part that has successfully passed these tests will be appointed an Executive Order number and will be listed on the CARB website for reference. Every Executive Order part or modification has an assigned number that can be verified by Smog Check stations, BAR Referee stations, or by the ARB. This number should be displayed on or near the emissions sensitive part for reference by a smog check technician. For a database listing of current exempt parts, visit: http://www.arb.ca.gov/msprog/aftermk...es/amquery.php What does it mean when an aftermarket product is advertised as "CARB Exempt" or "50 State Legal"? Although a part may be advertised as "50 State Legal", this may be more of a marketing statement than reality. Unless an emissions sensitive part has been issued an Executive Order number by CARB, or an EPA exemption, the part is NOT legal for street use. Parts that are typically appointed CARB exemptions include: headers, air filter/intakes, turbo kits, and supercharger kits. Parts that are typically not eligible for a CARB exemption include, but are not limited to: OBD II replacement catalytic converters (as of early 2005, only a few 1997 and later OBD II catalytic converters have been granted an exemption), downpipes or headers that remove or relocate a catalytic converter, and performance carburetor kits. Contact the manufacturer of a product that you are considering purchasing for details regarding that specific component. An exhaust system that is installed AFTER the catalytic converter is considered a "cat-back" system and is considered emissions legal. (Sound level restrictions may be an issue in your state, check with the exhaust manufacturer or you local authorities for more information.) Can I replace the OEM catalytic converter on my car with a "high flow" catalytic converter? The catalytic converter plays a major role in the emissions reduction of a motor vehicle. The vehicle manufacturer has matched a specific catalytic converter to the vehicle to minimize emissions output. Both CARB and the EPA do not allow the replacement of a catalytic converter with non-exempt "high flow" performance replacement unit. In fact, it is technically not legal to even replace a converter unless it has been proven by technician to have failed, and then it can only be replaced with an exempt OEM equivalent unit. (However, enforcement of this requirement is almost non-existent and is the primary loop-hole that allows the usage of so-called "high flow" catalytic converters. Many of these units are sold with the disclaimer as being a "race" component and are not intended for street use.) Due to the hundreds of vehicle models produced over the years, it is virtually impossible to determine by glancing under a car whether the converter is the original unit, a legal OEM replacement, or a non-legal aftermarket "high flow" performance unit. Unless CARB or the EPA decide to take more aggressive enforcement action, the installation and usage of these non-exempt "high flow" catalytic converters will likely continue. Can I remove my stock exhaust manifold/catalytic converter and replace them with a header/catalytic converter combination on my car? Not legally. As mentioned above, CARB or the EPA does not allow replacement or relocation of any of the stock catalytic converters. They require that all original catalytic converters be in their original positions, and replacement of multiple catalytic converters with a single non-exempt "high flow" performance unit is not allowed. Although using a header (or downpipe) and catalytic converter combination might pass a tailpipe test at a California tailpipe emissions test, it would NOT pass the visual inspection portion of the test. Since the engine configuration of the rotary engine in the RX-7 is rather unique, it is possible that some test station technicians may not be familiar with the this layout, and they may not even notice that a header (or downpipe) and/or replacement catalytic converter has been installed. Hope this helps. :wink
2003 Ford Mach
Man this was great great information!...thnx alot bro
[SIGPIC][/SIGPIC] Under my Umbrella! [I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I] |
#4 | |
Threads Similar to: California Emission laws...
| Can't seem to pass emission in Colo | jpowen | 5.0 Mustangs | 39 | October 14th, 2007 10:21 PM |
| EMISSION TEST | kampa | V6 Mustangs | 2 | June 19th, 2007 03:08 AM |
| Emission laws FL | acmillr | 99-04 | 7 | April 18th, 2007 02:28 PM |
| Emission Intakes... Cannot find any! | problemCOBRA94 | 94-95 | 2 | April 10th, 2007 12:58 AM |
| PA Laws... | rainydayryan | 99-04 | 7 | September 21st, 2006 09:51 AM |
