DIY: Refinishing Steel Rims (Video Tutorial)
How to refinish steelies on a budget. This involves repainting your rims using spray bomb/rattle cans.
What you'll need: flat screw driver, paint marker, wire brush, 200-400 grit sandpaper, brake cleaner, clean cloth, painter's tape, paper, dull knife/flat edge, primer, paint (color choice) Procedure: -remove rims from vehicle -mark where wheel weight are located with paint marker -remove loose rust and paint using wire brush -sand down rim using 200-400 grit sand paper -clean rim using brake cleaner and cloth, then let dry off in sun -tape off tire and valve stem -primer rim and allow for approximately 10min dry time -apply selected paint choice (3 coats) -let paint dry and remove tape -reinstall wheel weight -reinstall rim on vehicle |
Threads Similar to: DIY: Refinishing Steel Rims (Video Tutorial)
| Stormin norman, refinishing. | sickfox | 5.0 Mustangs | 9 | October 2nd, 2010 08:49 PM |
| Refinishing rims question | PhillyGT | 5.0 Mustangs | 10 | June 10th, 2010 03:20 PM |
| Firearm Refinishing | NastyFX4 | The Clubhouse | 16 | February 1st, 2010 01:46 PM |
| Moto STEEL Polished Stainless Steel Headers and H-Pipe | RX Bandit | 2005 - 2010 | 6 | October 5th, 2009 06:23 PM |
| Billett steel or forged steel flywheel? | weems | The Clubhouse | 8 | April 13th, 2009 03:21 PM |
