Discussing Brake Problems in the General Tech Forum. I just replaced my rotors and pads today becuase they needed it badly!!!!!!! Now the ...
Old May 30th, 2006, 01:30 AM   #1
00SoSlow's Avatar
Brake Problems
I just replaced my rotors and pads today becuase they needed it badly!!!!!!! Now the are squishy and i can almost hit the ground, kinda scurred to drive it... Anyone know what may be the problem???
Im stumped i checked the fluids and such............
2000 V6 Performance Red @ Cardomain Was fun but a waste...
1987 LX Hatch | Soon to be a 600hp monster
Old May 30th, 2006, 02:04 AM   #2
Moderator
turp's Avatar
1989 MUSTANG LX 5.0
16.17@86.21(bone stock on street tires)
Air bubbles, bleed them again.
SUPPORT YOUR LOCAL HOOKERS....HUG A TOW TRUCK DRIVER!
Donate to lxhatch@gmail.com
Old May 30th, 2006, 02:59 AM   #3
Did you pump them a few times before trying to test drive? If you dont there will be slack between the pads and rotors and the first time or two you try to use them they will be really loose till they pump up. :wink
Old May 30th, 2006, 04:09 AM   #4
Bleed them... the last time I did work on the braks I had to bleed them afterwards for a good 20mins.
Old May 30th, 2006, 09:23 AM   #5
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
+1
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old May 30th, 2006, 05:29 PM   #6
00SoSlow's Avatar
yea i pumped them back so the calliper was back on the pads but still really aquishy ill have my friend take a look at them, thanks guys
Old May 30th, 2006, 05:38 PM   #7
99mustang232's Avatar
1999 Ford Mustang V6
yeh gonna need to re-bleed them, this time make sure you start with the side farthest from the master cylinder, Passenger Rear > Drivers Rear > Passenger Front > Drivers Front. Make sure you keep pumping the brakes until the fluid has no bubbles, make sure you don't let the resivor go dry. also once it is going clear you will want to hold the brake petal in while a friend closes the bleeder valve.
...even fire and single cammin
Old May 30th, 2006, 05:50 PM   #8
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Did you remove any of the brake lines or hoses when you put the new pads on? If you didn't remove any lines or hoses you won't have to bleed the brakes unless you have a leak somewhere.
Old May 30th, 2006, 08:49 PM   #9
00SoSlow's Avatar
they were squishy before i did the change... but different from when i baught the car... im thinkin i have a leak somewhere, but don't know where and i did not take any hoses off or anyhting ill check them again to make sure tho
Old May 31st, 2006, 08:55 AM   #10
Grandpa
if you do what he said, your brakes will feel like new, that is unless you do have a leak.
Old May 31st, 2006, 12:58 PM   #11
00SoSlow's Avatar
no clue where the bleeder valve is... can someone fill me in
Old May 31st, 2006, 01:27 PM   #12
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
On the back side of the calipers.
Old May 31st, 2006, 02:39 PM   #13
00SoSlow's Avatar
is it like a screw... or is its a twist off thing, complete newb to this stuff
Old May 31st, 2006, 03:45 PM   #14
See picture
See picture also go to parts store and buy a one man bleeder kit
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old May 31st, 2006, 03:49 PM   #15
How to bleed brakes
One man kit instructions:
Insert the nipple LOL into the bleeder valve, open the valve pump the brakes until the bubbles are gone, close the valve, go to the next wheel.
Empty the little bottle on the bleed kit when it gets full, always keep the master cyl full or you will be starting all over again. Air gets in the line when you let the master cyl go dry.
Start with passenger rear, then driver rear, then pasenger front, then driver front.
Brake fluid will eat the hell out of paint......... Not immediately, but if you get ANY on the paint, wash it off immediately.
Have fun, and if in doubt, take it to a shop. It is not worth your safety if you don't feel confident in doing this
Threads Similar to: Brake Problems
brake problems 99blkcobra 99-04 20 October 12th, 2007 12:45 AM
Cobra Big Brake Kit Problems OcOnnor220 99-04 3 August 7th, 2007 04:35 AM
emergency brake problems usmcsawgunner 5.0 Mustangs 4 June 15th, 2007 02:26 AM
brake problems delindsay04 V6 Mustangs 4 January 15th, 2007 03:11 PM
I have Brake problems! mustangstud13 99-04 9 September 11th, 2006 12:18 AM
