Look Ma! My First Post!
Intermittent fuel pump priming issue, SOS!!!
My fuel pump was priming this morning as I was attempting to get the timing set after a motor swap. Its not priming anymore and Ive done some of the testing but I don't know where to go from here. I jumper-ed the computer test ground and fuel pump test connector but the fuel pump didn't turn on and I have less than 1/2 a volt at the pink/blACk wire on the fuel pump relay. I DO get 12v at the yellow wire at the fuel pump relay KOEO. I don't have any voltage at the inertia switch but I do know that it isn't tripped and its new. I hard wired the pump and turns on so that isn't the issue. I also check fuse links, all looked OK and look new so I'm stumped.
The red wire from the EEC power relay should be giving 12v to the inertia switch but I don't have any voltage there. From there it goes to the fuel pump relay eventually powering on the pink/black wire which turns the pump on. Am I getting warm? Interestingly enough as I was testing the tps I heard a "click" type sound so for giggles I turned off and on again and sure enough it was priming. Hooked up the other battery I had charging and once again no prime. EEC relay turns on...If I jumper the pink/black to the yellow the pump turns on!!! Please help? Ive been working on this motor swap for 3 weeks straight and desperately need some help getting it going so I can get to work tomorrow!!!...any and all suggestions welcome! Okay, as far as test results go (KOEO) I get the following: EEC Relay: red wire/org&blk wire 1.42 volts red wire 12v black/orange 1.42 green/tan? 1.42 Fuel pump relay: tan/black 1.42v red/blk 1.42v yellow 12v pink/black 0 Red/Green wire at ignition switch has 12v |
Threads Similar to: Intermittent fuel pump priming issue, SOS!!!
| fuel pump issue | 88Saleen | 5.0 Mustangs | 2 | June 12th, 2011 11:09 AM |
| fuel pump issue | 90mustang | 5.0 Mustangs | 4 | December 25th, 2010 10:00 PM |
| Fuel Pump Issue. | double0mustang | V6 Mustangs | 4 | November 25th, 2010 12:51 AM |
| intermittent timing/ rev issue | GTNBY2 | 5.0 Mustangs | 2 | June 21st, 2010 12:52 AM |
| fuel pump issue?? | mustanghunter | 5.0 Mustangs | 7 | June 24th, 2009 07:52 PM |
