DIY: Installing A Plug To Repair A Tire Leak (Video Tutorial)
Old August 5th, 2011, 10:33 AM   #1
ProStreetDriver is on a distinguished road
How to install a plug to repair a puncture/hole in the tread face of a tire. The sidewall cannot be repair as it is unsafe and illegal.
Procedure:
-remove tire from vehicle
-find air leak using soapy water and watch for bubbling
-remove object in tire using a screw driver, pliers, etc
-using the reamer from the tire repair kit, stick in the in the hole so it goes through to the other side, twist reamer to clean hole
-load plug into needle, center plug in needle
-stick plug 2/3 length tire with 1/3 left exposed to the outside
-pull needle straight out quickly without twisting
-cut off access plug using side-cutters, razor, etc
-pump up tire and reinspect for leak
-when all is done, reinstall tire on vehicle
Old August 14th, 2011, 10:26 PM   #2
warrior86's Avatar
2008 Mustang GT
warrior86 will become famous soon enough
Send a message via AIM to warrior86 Send a message via MSN to warrior86
good writeup. I had to do this back in May, and it was successful. Kit looked similar.
'91 Ford Escort LX - SOLD
'81 Chevy Corvette - SOLD
'94 Toyota Celica (Supra) - SOLD
'97 Ford Mustang - R.I.P / SOLD
'07 Ford Mustang V6 - "Dad's Ride"
'08 Ford Mustang GT - \m/ Rocking \m/
Threads Similar to: DIY: Installing A Plug To Repair A Tire Leak (Video Tutorial)
DIY: Refinishing Steel Rims (Video Tutorial) ProStreetDriver General Tech 0 July 31st, 2011 11:47 PM
tire repair? TweederGT03 99-04 16 August 4th, 2009 07:08 PM
o2 plug repair? superbeef1000 99-04 1 April 4th, 2008 01:49 PM
oil leak in spark plug hole acobraman 4V / SVT 7 January 22nd, 2008 09:23 AM
97 Cobra, Oil leak in spark plug hole acobraman 96-98 3 October 20th, 2007 02:40 PM
