2000 v6 tranny swap
Old August 7th, 2011, 09:11 PM   #1
Look Ma! My First Post!
Milkyoil is on a distinguished road
2000 v6 tranny swap
I need to know if this will be a direct and easy swap. mine is a 2000 3.8 and I believe a t5 5 speed trans. I found one used off a 1998 v6 5 speed. Dude claims it is the same. I just need to be sure before i purchase
Old August 28th, 2011, 03:56 AM   #2
2000 Mustang V6
Orangeline is on a distinguished road
I had to replace the transmission in my 2000 3.8 as well, the swap itself isnt that complex. all we had to do was put it up on jackstands, drain the transmission fluid, remove the driveshaft, unbolting it from the rear end (they have those special bolts holding it on but i was able to use a metric socket that worked well.) if i remember correctly some fluid should come out when the driveshaft is pulled so a pan underneath is advised. there should be about 8 bolts on the bell housing holding it up, as well as a couple brackets near the middle of the transmission, i think. after placing blocks or a jack under the transmission you can just unbolt it and it should slide right off. i dont think the exhaust is in the way, i did this a couple of years ago. also, it is a lot easier with two sets of hands, the transmission is kind of heavy.
as far as the fitment of the 1998 t5 goes, i think it should fit, but there are a ton of knowledgeable people around here, one of them will be able to tell for sure.
Threads Similar to: 2000 v6 tranny swap
2000 Mustang GT swap...need help TimothyJames26 99-04 37 January 28th, 2012 10:51 PM
2000 3.8 v6 5 spd manual tranny swap out?? abbe5710 V6 Mustangs 8 March 26th, 2011 10:54 PM
tranny swap in a 2000 mustang? trusttheref 99-04 2 November 3rd, 2010 03:06 PM
2000 v6 engine swap? jhess623 V6 Mustangs 13 July 16th, 2010 01:06 AM
LT's in a 3v swap 2000 GT? Modmotor4life 99-04 0 June 5th, 2010 07:41 PM
